How do you program a modellfun esc?
Jammin
Jammin's Avatar
How do you program a modellfun esc? - 04.04.2008, 12:42 PM
The instructions that come with modellfun esc's are horrible, I've been trying to sink my esc with my reciver with no luck. If any one has any input please help me out. This is what I have so far, and I don't know if it's right.
1. Remote on and all settings to neutral (factory settings)?
2. Motor connected to esc and esc to reciver
3. Plug up your battery and you will hear two beeps?
4. Move throttle in to full reverse until it beeps rapidly? How long?
5. Then move the throttle to full forward. How long before you let go? Should I get any beeps before I let go, if so what kind?
6.The beeping will stop after a few seconds (which series of beeps)? Just wait a few seconds and the esc will be armed.
7. Do you need to remove the power and plug back in to operate?
If anyone else wants to give their input, please do so. You can edit the whole thing if I'm off on anything, I'm trying to get some instructions like the mamba because I don't seem to be smart enough to program these esc's with the modellfun directions.
04.04.2008, 12:49 PM
Here you go again
http://www.modellfun.com/b2b/service..._manual_en.pdf
83gt
04.04.2008, 12:50 PM
sheesh. how many places can you post this question ?
Jammin
Jammin's Avatar
04.04.2008, 01:10 PM
Three to be exact, don't people look in different sections of the forums? Or does everybody spend all their time surfing forums to not help like you. If you don't have anything to help me out, mind your own buisness.
83gt
04.04.2008, 02:32 PM
Touchy much ? Take a valium and sit back with the PDF that Arctk1 posted for you. There's my helpful advice, RTFM. ;).
J.
Jammin
Jammin's Avatar
04.04.2008, 03:05 PM
I'm not touchy, some people just don't take crap from a screen name.
Jammin
Jammin's Avatar
04.04.2008, 03:06 PM
Thanks again for your help.
lutach
lutach's Avatar
04.05.2008, 10:26 AM
I did the second setting on mine:
1. --no need to set up Throttle itinerary ---- startup process
pull throttle into the lowest position -- → ESC power connecting → Detect and get throttle signal one beep tone "beep" → 3 seconds delay → detected throttle lowest position → one beep tone "beep" again → can start throttle Moved.( start flying). this step total beep twice . there had light on ESC when each beep tone .
If not detected throttle signal, "beep, beep and beep ... " continued beep tones are emitted.
If the battery voltage exceeds voltage, "BEEP, BEEP, BEEP ." continued beep tones are emitted. the beep tone
pause for a bit longer,Under such circumstances, ESC refused to start motor.
2.need to set up Throttle itinerary ---- startup process
pull throttle to the highest position -- → ESC power connecting → Detect and get throttle signal one beep tone "beep" → detected maximum throttle position, "beep" tone is emitted (one beep tone) → then pull to the lowest throttle position → 3 seconds of delay → "beep" tone is emitted once, Detected the lowest throttle position → can start lifting the throttle. three beep tone is emitted .
Note : This method set up the throttle itinerary is not saved. throttle itinerary can be set up and saved permanently by our programm card.
I hope this works for everyone.
Jammin
Jammin's Avatar
04.05.2008, 01:46 PM
I got it figured out. I had to max out all of the settings on my xs3 pro then it worked. It was on some boat forum. Thanks everybody!!!!!!!!!
t-maxxracer32
t-maxxracer32's Avatar
04.05.2008, 04:45 PM
most people i would think just click on the "new post" option.
so they can see all the new topics.
if you post more than one thread then it will show.
so its really not needed to do more than one
t-maxxracer32
04.05.2008, 04:46 PM
Jammin
Jammin's Avatar
04.06.2008, 02:16 PM
I didn't see the new post section, I always looked at individual sections. My bad! I'm new to forums.
