V-Twin Velinions in Revo....build from scratch -
04.16.2008, 09:47 PM
Finaly got 80% of my parts and started the build...I was going to start with a rtr that I bought but we started using the nitro at rhe track so I decided to build this project from scratch
I'm going to be using two vxl systems with two heat sinks with double fans on the motors and fans on the esc's also two maxamps 8000mah 3s lipos...anyone got a sugesstion on what center drivelines will work?
Looks great so far!! My only recommendation is to make some sort of cover to block the holes/cut out underneath the spur gear. It seems that rocks can bounce up into it pretty easily. But other than that, awesome work!!
Hey what wrench set are those? I need a good set and my LHS only sells individual wrenches...
Got them at Harbour Freight but Dont waist your money they suck.....
get these they are fantastic and cheap the have ball ends and gauranteed for life......I have been putting my set through he** and there still working good as new
Checking the fit of the 8000 lipo and 8 cell nihm......the wheelie bar hooked up nice and tight .....also checking placement of esc's
still waiting for some stering parts,servo and the body (desert rat)
also if you read this mike...I need front and rear center driveshaft .....do you think I can find something that will fit or will I have to have it custom made
