rcmonkey
Team Thermal Racing
rcmonkey's Avatar
04.21.2008, 10:22 AM
Thanks I have got it now, you are going to mount the rear drive cup on the bit that has the bullet shaped thing on it?
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
brushlessboy16
brushlessboy16's Avatar
04.21.2008, 10:24 AM
close, im not going to use the bullet thing, From what i hear you can slide the motor shaft so that it sticks out both ends of the motor-so i can put drive cups on both ends
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
04.21.2008, 10:27 AM
Sweet, I may put one of these in my XB8, I will watch this thread closely.
Cheers
My Rides:
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
04.21.2008, 02:31 PM
Hmmmm, are you sure the motor will fit? I just took the CD out of my buggy and the distance between the ends of the CVDs is 40mm, going by the specs on the website the motor is 55mm long. Do you plan to cut the shaft?
What drive cups are you using? I found these which look goodhttp://www.rc-monster.com/proddetail...RCM8mmdrivecup
My Rides:
brushlessboy16
04.21.2008, 02:57 PM
standard drive cups are 8mm, the originals on my raze's front and rear pinions are. I chose HotBodies Cups because they were cheap. I will need to find one shorter Cvd, that will be decided when i mount the motor... it should be here soon.
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
04.21.2008, 03:56 PM
Ok thanks, do you have any other information about moving the shaft inside the motor? I found a picture of the shaft and there is only notches for e clips or something similar, I don't see how it could be adjusted.
http://www.hobbycity.com/hobbycity/s...idProduct=6495
My Rides:
brushlessboy16
04.21.2008, 03:57 PM
the e-clips are to be removed, the shaft will be held in the motor by the setscrews it has. :D
04.21.2008, 04:03 PM
...Minding that the Buggati V16 Veyron...
Isn't it actually a W16?
brushlessboy16
04.21.2008, 04:15 PM
Ugh darn! FOILED AGAIn!
indeed it is a w-block
that must be one nicely machined peice of aluminum....
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
04.21.2008, 04:38 PM
Sweet, are you just going to dremel a flat in the other end for the drive cup?
My Rides:
brushlessboy16
04.21.2008, 04:43 PM
yep that is the plan :D
Takedown
WARNING: May become violent.
Takedown's Avatar
04.21.2008, 05:29 PM
When was your stuff shipped out on? Im excited to see this thing finally get completed.
RIP- Tammy (9/14/08)
brushlessboy16
04.21.2008, 05:40 PM
Its being processed as we speak. all of the item s are reserved for me. UGH THE SUSPENSE IS KILLING ME...
What do u guys think about the motor mount?
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
04.22.2008, 06:07 PM
A simple L shaped bracket that mount on the CD holes would be easiest.
Name:	Outrunner mount basic.jpg
My Rides:
brushlessboy16
04.22.2008, 06:50 PM
yeah i was thinking something like that. but a little more bracing, to keep it from flexxing. like this
http://www.rc-monster.com/forum/atta...9&d=1208784154
