Losi eight Q's.
Sylvester
Sylvester's Avatar
Losi eight Q's. - 05.27.2008, 03:19 PM
Hey guys got some questions ;
Gonna use a Pro factory roller eight buggy, with a flightpower 5000 4s. Is mikes battery mount a direct fit for this buggy?
- Im planning on using a Neu 1512 (not sure on kv) with mikes nylon back cover and front plate, will it run well with a MM w/CC bec?
What gearing would be reccomended for this setup depending on motor choice?
Thanks!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
8ight
ilpufxit
ilpufxit's Avatar
8ight - 05.27.2008, 05:14 PM
I'm running the same motor on 5s and it rips. It will work on 4s with MM. The battery mount should fit, you just need to check body clearance. Battery height of 38-40mm is max unless you want to cut or raise the body.
