Lipo -
02.25.2005, 04:22 PM
can you run these oln BL and if so which ones or are they not recommneded foir bashing?
02.25.2005, 04:26 PM
02.25.2005, 04:27 PM
no but what about flextech?
Site Owner
02.25.2005, 10:25 PM
LiPo and brushless go hand in hand (higher efficiency and less weight).
02.25.2005, 10:26 PM
so better then a 7 cell pack of 3300's? if so which ones and what charger? good for bashing?
Site Owner
02.25.2005, 10:39 PM
The good lipos will out perform the nimh batteries in pretty much every way. They need a LiPo specific charger, and it is important to follow the safety procedures when using them (like any battery).
02.26.2005, 09:21 AM
okay.... i heard that they can explode or something like that? is this ture?
Site Owner
02.26.2005, 10:15 AM
Any battery can explode (a battery is basically stored energy).
02.26.2005, 10:16 AM
oo okay.. so i think i might stick with a good old fashion 7 cell pack cause aren't lipo alot?
Site Owner
02.26.2005, 10:23 AM
LiPo are either expensive or cheap, depending on how you look at it. If you think about them in a similar way to thinking about brushless. The up front cost may be a little higher than other options, but the long term costs will be a lot lower (brushless motors last a lot longer than brushed motors with no maintenance cost either - LiPos batteries have more power, less weight and are capable of up to ten times the number of cycles than a nicad/nimh battery is capable of).
02.26.2005, 11:27 AM
well in that case it is a good deal i guess but aren't they like 100 dollars per battery or more i think?
02.26.2005, 12:14 PM
Not really - 3200 7.4 volt packs go for about 80 bucks - not much more than a good matched GP3300 but at HALF the weight!
Thing about lipos and brushless is that you have the option to go higher voltage - such as 11.1 volts or 14.8 volts.
02.26.2005, 12:15 PM
so what batteries and charger then?
02.26.2005, 08:58 PM
if you plan on keeping your nihm batteries then i would recommend the duratrax ice charger. its about $130 and can do lipo's as well as nihm and nicd.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Site Owner
02.26.2005, 10:12 PM
The ice seems to be a pretty nice charger, but don't forget the power supply!
