Traxxas E-Revo: what all needed to go brushless single motor?
Cain
Traxxas E-Revo: what all needed to go brushless single motor? - 06.05.2008, 08:58 PM
Looking into the stuff coming out for the new E-revo, I see they have some single motor mount stuff. what all do you need to do a single motor setup?
83gt
06.08.2008, 08:48 AM
The single motor mount, a suitable BL motor, an ESC to run it, and some good batts. The rest is up to you.
Jeremy1976
06.08.2008, 10:24 AM
You can also utilize the stock mount from what I was told.
Cain
06.08.2008, 10:56 AM
Thanks for the info guys!
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.09.2008, 06:02 AM
Yeah I read that someone aswell. Traxxas did it as probably 90% will be converted to brushless anyway
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
stum
06.09.2008, 11:25 PM
I would highly suggest going w/ the Neu 1515 1.5d, this is the best motor on a 4s setup you can find.. it is amazing! 50mph w/o temp issues at 4s lipo. You can run up to 6s w/o issues though at that point you are pushing 65-70mph (no joke).
Lipo's I would highly recommend going w/ the maxamps.com 2x 2s2p 8k with the hyperion 0610i duo charger.. amazing combo, a bit all at once but it is worth every penny! That charger is by far and away the best lipo charger on the market, but it does require a power supply; convert a pc supply or snag one from radio shack that is ready to go. You will need a Mamba Monster Max esc or a MM esc if you just want to stick w/ a 4s lipo config (best for racing) but with the MM you need an external BEC. The only other thing I can think of you will need would be a 5mm pinion w/ the 1.5d I would get a 22t pinion and the 58t spur.. awesome, I mean awesome combo! ohh and as you mentioned the single motor mount :)
