Isn't a Mod 1 pinion a Mod 1 Pinion?
BushyAR15
Isn't a Mod 1 pinion a Mod 1 Pinion? -
07.04.2008, 10:16 PM
So, I'm converting my E-REVO to BL using the Novak 6.5 HV MAXX system.
I also bought a Mod 1 pinion, 13 tooth 5mm shaft-bore. When I tried to install it, it doesn't mesh with the spur gear!
Is there something I'm missing here? Isn't the E-REVO spur a 32 pitch gear?
BushyAR15
2
07.04.2008, 11:12 PM
E-ervo is same as emaxx 32p IIRC or mod .8
Find all posts by Arct1k
3
DRIFT_BUGGY
07.04.2008, 11:48 PM
32P is 32P, MOD1 is MOD1. MOD1 are pretty much on nitros.
You require this one
http://www.rc-monster.com/proddetail...nion5mm&cat=40
which is also 5mm bore. Do you want a 5mm bore?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
Visit DRIFT_BUGGY's homepage!
Find all posts by DRIFT_BUGGY
4
TDC57
07.05.2008, 01:18 AM
If you haven’t upgraded your output shaft to 5mm then just buy a 32 p pinion gear and you'll be good to go.
Nothing!.. Hahahahaaa..
TDC57
Find all posts by TDC57
5
BushyAR15
07.05.2008, 07:04 PM
Just verified, the REVO spur matches up with the Mod .8......
Thanks
BushyAR15
Linear Mode
Switch to Threaded Mode
