hacker for 8th scale on 4s
83gt
hacker for 8th scale on 4s - 07.18.2008, 05:14 PM
Hey all. I have a converted hellfire that does not agree with cheap feigao's. Lucked up on a sale thread for some used hackers at a good price. Would you go 8xl and gear up or 7xl for use on 4s lipo ?
Just want your thoughts :). If the feigao's aren't holding up for me, is hacker enough higher quality to handle a fairly heavy conversion on the relatively lower voltage of 4s ? I'm wanting to get the 2 pole hacker so I can use my bk9920. I was leaning toward the 8xl so I would have room to jump up to 5 or 6s in the near future....
hacker 8xl = 1973kv
hacker 7xl = 2254kv
jnev
jnev's Avatar
07.18.2008, 05:22 PM
I'd go for the 8xl. Gives you much more room for gearing changes, and you can run a higher voltage if you ever wanted to. The 8XL should run cooler as well.
07.18.2008, 05:55 PM
Yep, 8XL would be great. Probably gear it very similar to the feigao it replaces, assuming that was an 8XL also.
83gt
07.18.2008, 07:49 PM
Was running 9xl on 15t, currently 8xl on 13t after the 9xl fried. I have 13,15,18t mod1 pinions.
J.
