Lipo's and capacity
Electric Dave
Lipo's and capacity - 07.20.2008, 08:52 AM
As Lipo batteries die, do they loose capacity? I usually run 5 min runs with about 2 mins of warm up laps so my batteries are rarely fully discharged. Yesterday I decided rather than charge between rounds, I'd run the same pack for two qualifiers. Late in the 2nd qual, my radio was complaining about low voltage (I have a nomadio set to tell me when they get to 14 volts) so I babied it around the track and never actually hit the LVC but I was darn close. Anyway when I got them on the charger, it said they were at 9% and it proceeded to put only about 3800mAh back in...they are 4900's...does that mean my batteries after 3 seasons of racing are starting to go? Might they rebound?
Duster_360
07.20.2008, 04:21 PM
From what I've seen with mine, yes, they start to loose capacity as they get older and build the number of disch/chrg cycles. The most used ones I've had were for 18th scale and were 1500mah. After a little more than 100cycles thery were charging to only low 1200's after being run to 6.2v cutoff. When new, they would routinely see 1575, a drop of 20+%.
I assume IR goes up as well as they age, although not to the point with NiMhs.
