8ight-t gear ratio?
snowhack
snowhack's Avatar
8ight-t gear ratio? - 07.29.2008, 03:35 PM
What is the gear ratio of a Losi 8T? I know this sounds dumb, but I can't for the life of me find it.
I'm triing to find what kv BL motor I would need and I need gear ratio info.
Losi 8ight-T
Losi XXXT BL
DTX Evader (Chick Hicks)
DTX WarHead Goin BL
jayjay283
jayjay283's Avatar
07.29.2008, 05:03 PM
the diffs ? 43/10 or 4.3... link ....dont know what spur and pinion you are running
Chapito
07.29.2008, 09:01 PM
I run 14/48 with a 2200kv, 1515/1y Neu motor. Calc's out @ about 37m.p.h., which I've found perfect for racing with the nitro's. Only the highly modded or higher geared ones can match me down a long straight.
snowhack
snowhack's Avatar
07.30.2008, 03:08 PM
I guessed on the conversion link I found somewhere here and came up w/ 2300 KV...so I was close. Thanks.
So I'm looking for more on the torque side of the kv range than speed? I know the deal w/ winds on brushed motors, but have always been a little confused about BL. Outrunner, inrunner, 2.8mm shafts, 5mm shafts, 1/8th" shafts.... Why can't they just come up w/ a HP/Torque dyno chart w/ an RPM range like full scale engines. Thanks again.
Losi 8ight-T
Losi XXXT BL
DTX WarHead Goin BL
heidy_james
04.21.2010, 12:46 AM
Boasting user-friendly, track-tested tuning setups from top Losi racers the 1/8-scale nitro powered 8IGHT-T 2.0 Truggy Race Roller is professionally dialed and assembled in a race-ready configuration. The 8IGHT-T 2.0 builds upon the innovation of its predecessor by offering 37 newly engineered features and design elements. Also provide perfect gear ratio.
George16
Supermaxx
George16's Avatar
04.21.2010, 01:36 AM
Huh .
You need to share whatever you're smoking.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
FG101C
04.21.2010, 01:59 AM
The best setup I ever ran in my 8ight-T, out of four different setups, was a 1700kv Tekin buggy motor, 5s 30c LiPo, MMM and a 50 tooth spur with a 16 tooth pinion. It was perfect in my opinion, had plenty of torque great speed an controlability.
That's exactly what I would do if I were to build another one.
Just my .02 cents.
itbvolks
04.21.2010, 11:02 AM
Just my .02 cents.
I'm running a mugen MBX6T but this is almost EXACTLY the same setup I'm running. I'm using a RX8/1700kv truggy motor, 5s 35c LiPo, geared 16/46. I just picked up Mike's delrin 50T spur for the slipperential so I'll be running either 16 or 17/50 depending on track size.
I had zero issue with torque with the 16/46 setup actually. Plenty available all the time (no current limit, Zero timing on the motor)...
stum
05.01.2010, 10:30 PM
I run the MMM 1y combo on 4s lipo with 13/50 gearing and race vs nitro on a pretty big track; my last race I tq'ed and took 2nd in the a-main.. would have done better but my battery came unplugged about 1/2 way in!! Lost 3 laps and still pulled #2 :)
