hey guys i am looking to change to 1/10 wheels and tires for my crt.5 traxxas rims i heard will fit is it a direct bolt on can anyone help, which rims are the right ones. thanks
Reason: fix
I'm planning to use the electric rustler rear rims( they have greater offset than the front ones with 12mm hexes).
Get to of these with your choice of 2.2" truck tires and you'll be ready. http://http://www3.towerhobbies.com/...3&I=LXJF49&P=K
Nice to meet you!
I've been using HPI 2.2 truck wheels for a while now, with 2.2 truck tires, of course. Anything that uses a 12mm hex will work, if you install 12mm hexes onto your axles. They might require some shimming (Traxxas makes 5x8x.5mm shims), but will work.
