mxracer
08.12.2008, 04:54 AM
well i just ran a full flight power 5000mah 5S pack through my hyper st with a 1515 1.5d (2700kv) 52spur / 11t pinion
mamba max with 25mm fan , no other mods
9 mins runtime and 60 deg C motor , and esc , batts about 40deg C
im pretty sure if the 1515 1y is geared correctly a MM , MMM or mgm 16018 will handle it fine
losi 8ight-t 1515 tekno 1Y/MM 4s/5S flightpower
losi 8ight-t 1515 tekno 1y/MM 4s/5S flight power
RIP 4x MMM . MM still lives on !
ReV:-O
RC-Monster Carbon Fibre
08.12.2008, 07:27 AM
Neu Motor Specs:
http://www.drcwebservices.com/ffe/neuspecs.htm
gramey
gramey's Avatar
08.12.2008, 08:53 AM
Thanks for all your help, it would appear from your replies that 160 amp esc should be fine.
Losi 8T RR - Novarossi Plus 21-5BT/ Jammin JP3 - Teknorc 8T - Neu 1515-1Y - MGM 16025-3 Z Series ESC.
B4maz
08.12.2008, 11:56 AM
Originally Posted by GriffinRU View Post
I will disagree,
Maximum current is at stand still or lowest RPM not at max RPM. You will never see 55A at 60000RPM with 1515/1y running at 27V.
Maximum current for Neu 1515/1y is 110A
Running current with rated load should be around 40-55Amps.
Better picture can be obtained from motorcalc or my program.
I can publish rated current for all motors if required.
The Kt in your program for the 2215 series is opposite. It should be:
Kt (InOz/amp):
2215/1Y- 0.938
2215/1.5Y- 1.325
2215/2Y- 1.802
2215/2.5Y- 2.253
2215/3Y- 2.816
bl-is-future
bl-is-future's Avatar
08.12.2008, 12:08 PM
"I thought I was wrong once but I was mistaken." i love that saying.
