kulangflow
Never Fast Enough
kulangflow's Avatar
08.13.2008, 02:56 PM
Originally Posted by E-Traxxer View Post
What I think is going to happen, is that our transmitters are actually going to be somewhat like mini laptops (the way computer tech is going..) and they will have a wireless link to our RC. The screen(s) on our transmitter will allow us to see temperatures, time, altitude, angle, speed, motor speed, amp draw, mah used/left (etc etc) and any broken or weak parts on the vehicle. It will also display the weather conditions and alert you if the weather is going to change so you should head in. It will have a link to the internet (or future equivalent) which means that it will have parts lists and the like. When a part is broken, the transmitter will know which one, and you can order it right there on the spot with your remote. You could also use the remote to wirelessly change the settings on the vehicle.
Now THAT sounds cool! (and mostly realistic!)
Sign me up!
J3110
Originally Posted by Fast5sRevo88 View Post
This year Nic Case wins once again with his streamliner powered by 4 Neu 6500 series motors and 40s lipo on each motor. "This run was only possible due to my built-in vacuum pump that creates the vacuum of space around the car that eliminates all drag." Maybe 1/5 scale brushless cars will be more mainstream, or maybe Mike could make a Baja 5b motor mount before that.
Actually, that would be the shock wave produced by "Nic's" 1:1 R/C breaking the sound barrier on the playa.
Have a ride:
J3110
08.13.2008, 03:14 PM
Sign me up!
I would have to agree. Essentially that was what I meant with the "omnicomm".
The PC is going to get much more personal and much more portable with alternative input/output methods.
We already have wireless video and full-on FPV with HUD, GPS I/O, RTB, LCD goggles, 3 mile-plus TX range and the lot. It's just going to be a matter of how we use that tech.
Like an "R/C bash" is going to be the new online gaming where you might drive somewhere and engage in some kind of activity, but you could all be hangin out in an air-conditioned room or whatever eating chips while also running your R/Cs outside.
While I like the whole sensors in all of the parts idea and ordering new ones online while you're doing a flair off the half-pipe with your s00-par-maxx, necessarily. I mean, there is such a thing as too much multitasking...this isn't like an AM/PM where you can never have too much good stuff in my opinion, but of course, to each their own and such. :)
I think at a certain point, it is better to keep the RC setup "simple" and clutter-free and also that parts that often break(will they even be breakable in the future, I wonder?) are also affordable. So, depending on the cost of the imbedded nano-sensors...maybe it won't be an issue either.
Remember "Robot Jox"? LOL
crazyjr
crazyjr's Avatar
08.13.2008, 06:35 PM
There was a similar one to this thread on URC, but it was foir 100 years from now.
I see the esc being different from what it is now, Most of the current and grunt work would be done by the motor, the current and voltage. The esc as we know it now, would be just a brain and black box. Batteries will still be there, but to start the process of the water based fuel cell in all electric rc's. I see pitstops for water for unlimited racing and bashing. Nitro will be different as well, As we get away from fuel based society, I see air powered rc's being popular. There is a 1:1 based one being tested in europe. With an optional HV pump, it could go longer, But most racers will not use them for weight and have a tank full of air for pitstops.
What i'd like to see is a plate based shock ssystem where the shock is replaced with a couple of magnetic plates that flip polarity to provide shock and spring action. The main problem would be those with pacemakers and track debris
J3110
08.14.2008, 12:10 AM
Originally Posted by crazyjr View Post
...water based fuel cell in all electric rc's.
Like this?
crazyjr
crazyjr's Avatar
08.14.2008, 12:34 AM
Originally Posted by J3110 View Post
Like this?
yeah, i seen that. But better output for racing and true fun
