JThiessen
JThiessen's Avatar
09.06.2008, 11:09 PM
Originally Posted by 123revo View Post
ah its good to see patrick and co are RoHS compliant. green manufacturing, the way of the future. yes that lead free solder is a royal pain to work with without the right tools/ solder iron. i just gave mine to one of the shop guys and hey presto...all soldered. TBH if i was to do it, i would have used the leaded solder, i am very impatient.
123.
Cheater.....!!!!!
brushlessboy16
brushlessboy16's Avatar
09.06.2008, 11:16 PM
Cheater.....!!!!!
you know the thing i dont get is
My solder wouldnt blend with theres...mines lead free 96/4
but it works fine by itself
123revo
09.07.2008, 05:04 AM
Cheater.....!!!!!
i resemble that remark. however we have irons that melt it in nanoseconds, they are the metcal irons try circa $1000 an iron and $100 a tip !!! nah i will spend my cash on lipos after all i spent 7 years soldering and dont do it unless i have to. my V2 is humming away nicely, love the funky sounds on boot up. am i the only one who gets nervous when soldering the connectors on the li-pos?
long live the MMM
123.
xtremelimits285
E8ight T
xtremelimits285's Avatar
09.07.2008, 12:20 PM
The wire's don't have male bullets on them on one end? Mine did, and the only thing I had to solder was my choice of ends to connect the motor (I used 6mm bullets for that). I did attempt to use 4mm, but the wire wouldn't fit into the socket on the bullet.
Originally Posted by JeffEmbracedDC View Post
As did all of mine..
no theres no males soldered on any of the wires, both sides of the wires are tinned..
i tryed a set of 4mm's an crap is the tinned solder hard to melt, i had a friend try to put on the 4mm's and no luck, my 80-120watt gun needed a new tip, try or 30mins..
ill just get some 6mm's or 6.5mm's and have the hobby shop down the road put them on, as it probley only takes the 5mis..
im going to use 2 screews to hold down my MMM to my RCPD top plate
and also use 2 zipties just incase...
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
Kajman
Kajman's Avatar
09.07.2008, 12:24 PM
Any news about percentage of dead MMM v2?
e-mike
e-mike's Avatar
09.07.2008, 12:27 PM
9% i guest.....
80(more at this time)unit died on 3000 made
D8t on juice!!
JThiessen
JThiessen's Avatar
09.07.2008, 01:10 PM
Originally Posted by e-mike View Post
9% i guest.....
That only makes 2.6%
JeffEmbracedDC
JeffEmbracedDC's Avatar
09.07.2008, 06:01 PM
My MMMv2.0 BEC outputs 6.05v. I assume they changed the bec from 5.5 to 6.0v when they designed the v2?
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
e-mike
e-mike's Avatar
09.07.2008, 06:04 PM
i know...it why ive wrote 9%because now its really 9%
D8t on juice!!
Mister-T
09.08.2008, 12:10 AM
6.05 volt unloaded, voltage may drop under load even if there is a regulation
"We'll never have a ROAR legal motor. They're all copies of Novak's design. We're not willing to copy what we consider to be an inferior motor"
- Joe Ford - my new hero
George16
Supermaxx
George16's Avatar
09.08.2008, 09:04 AM
Patrick, your pm box is full.
Anyway, here's my message.
The replacement V2 which was shipped on Aug 28 and received last Friday, Sep 5th is dead. I started a thread about it under CC forum.
http://www.rc-monster.com/forum/showthread.php?t=14844
Anyway, I want to know if it's okay with you to do the BrianG mod and run it with my rx pack without voiding the warranty if something worse will happen. I know some forum members were given the go-ahead to do the mod without voiding the warranty since the MMM is not working naymore.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
jhautz
jhautz's Avatar
09.08.2008, 09:11 AM
-Jeff
My V2 puts out 6.0v and my V1 put out 5.42v. I definitly think it has been changed from the origianal 5.5V standard.
to make it...
or break it...
Silent...But Deadly
xtremelimits285
E8ight T
09.08.2008, 11:03 AM
Yep , i put the volt meter to my v2 MMM and im seeing 6.0v on the MMM's bec...
With my MMM plugged in & my Futaba Digital S9351 servo plugged into my Futaba 2.4Gh 6ch Rx i am seeing 6v-5.95v, an when turning the steering servo to full lock(left or right), im seeing 6v-5.9v...
Now just for 0.2-0.5sec it drops to 5.8-5.75v when turning, but thats when the servo first moves under a Heavy load / my hand pushing down on the frontend an holding it down, but after 0.2-0.5sec it goes right back up too 5.8v-5.9v even while still loaded up / me pushing down on the frontend....
So the lowwest the new v2 MMM's bec drops is 5.75v, Under a Heavy Load.
Gary Antonietti #9
09.08.2008, 11:05 AM
I might have to get a MMMv2 and test the BEC like some of the other tests I do. Curious about efficiency, noise, etc...
jhautz
jhautz's Avatar
09.08.2008, 12:16 PM
If you can get it to last long enought to test. lol
to make it...
or break it...
Silent...But Deadly
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
