MMM owners....something weird happened
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
MMM owners....something weird happened - 09.24.2008, 04:33 AM
I was running my MMM today on 4s (TRC 8000's) in my E-Revo. Just going up and down the street.
Out of nowhere it put the breaks on for half a second.
It jerked like it hit a wall. Looked like the front end squated down and bottomed out.
when it happened....I was rolling forward and had started to pull the throttle.
Has this happened to anyone else?
Almost seemed like a radio glitch.
Trying to think of any other info that may be important.....
um...I'm using a Ubec. Didnt do any warranty voiding mods to the MMM. Just some Case mods.
I'm stumped.
I tried, but I cant get it to happen again.
Maybe some 2.4G frequency glitch?
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
JaySki
JaySki's Avatar
09.24.2008, 10:02 AM
That is usually the beginning of the end.
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
09.24.2008, 10:22 AM
To me, that sounds like a radio glitch of some sort (though I guess the ESC can't be ruled out). Are you on Spektrum? They're not impervious to problems unfortunately (being on DSSS), and this sort of thing's happened before. Did the ESC run fine after that?
bl-is-future
bl-is-future's Avatar
09.24.2008, 10:29 AM
go to the same exact spot and run again and see if it does it. If it does then go to a completely different spot and check there. If it only does it in one spot it is the radio. If not it is most likely the beginning of the end.
lucias
lucias's Avatar
09.24.2008, 10:42 AM
A guy at the track had an issue where his stopped on the back straight away for 30 secs or more and then started working again.. His looked to be a radio glitch he raced the next couple of times without a problem..
hoovhartid
hoovhartid's Avatar
09.24.2008, 01:36 PM
Yup, its a Spektrum DX3.0
The ESC seemed to run fine afterwards, I tried but couldnt get it to do it again.
No problems running in the same spot...its in front of my house. lol
Do 2.4ghz cordless house phones mess with a spektrum signal? I'm pretty sure my neighbor has one. maybe she got a call? who knows...time will tell I guess...
beginning of the end? this has happened to someone else then?
JaySki
JaySki's Avatar
09.24.2008, 02:01 PM
Mine would stop.. and stutter for a second.. Then run a bit.. then it gets worse... and then dies. Might be a radio glitch.. just sounds a lot like how mine died.
Sower
Sower's Avatar
09.24.2008, 02:02 PM
That would be me Since then I have had one other time practicing where I just seemed to loose throttle or brakes and the car just coasted. After the first time at the track I wrapped the RX in tin foil thinking it might be the Spektrum. Still don't know for sure what the problem was. I had steering on the second time and I was only about 15 feet from the vehicle. After about 15 seconds it ran just fine. No temp issues either.
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.24.2008, 02:15 PM
As good as 2.4 is they are still not impervious to glitching. I wouldn't raise great concern unless it happens more.
www.cubicle101.com
JThiessen
JThiessen's Avatar
09.24.2008, 03:04 PM
My B'in Laws stock Emaxx does this when we run with a buddy's rig, which is running a JR radio system. Dont know why or how, but that JR radio is periodically interferring with his stock radio system.
Sammus
Sammus's Avatar
09.24.2008, 07:25 PM
Could be a solder connection on the motor side...maybe? Like if something came loose then that third pole wouldnt be energized and it would kinda be trying to keep the rotor locked in one position. then if the joint was bumped back into place it would function normally again...
not likely, but worth checking i think
tc3_racer_001
tc3_racer_001's Avatar
09.24.2008, 07:54 PM
from what ive read the spektrum dx2/3/.0 systems are the most glitchy of the lot. futaba seems pretty glitch free, but im looking at upgrading to a react - 2000ft range and usb connection - YES PLEASE! (and its pretty cheap too... )
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
lutach
lutach's Avatar
09.24.2008, 08:10 PM
Yes or it's shorting out with the heat sink. Mine seems to have all the three phase plugs contacting the heat sink.
auto2
09.24.2008, 09:39 PM
is your fail safe on the radio set to neutral? maybe it got set to reverse? you set it when you bind the reciever to the radio.
mmazurek
09.24.2008, 09:42 PM
Have you opened a beer with it?
