e-rev project
10.06.2008, 12:37 AM
i never thought a RCM thread could have this much drama, except that girlfriend one a couple months ago :0 :)
TDC57
TDC57's Avatar
10.06.2008, 01:45 AM
This would make one hell of a "battel truck" Takedown...
Think about it..
Nothing!.. Hahahahaaa..
SV6000
SV6000's Avatar
10.06.2008, 05:27 AM
Hey i know his name is taboo around here but there is a Baja 5B brushless setup for sale from finedesignrc.com I am not saying that you have to buy it but at least look at how someone else has done it and what they have used and use that to get some ideas and how to mount it.
Takedown
WARNING: May become violent.
Takedown's Avatar
10.06.2008, 04:41 PM
It will be a peice of cake to mount the motor. Im ordering a 3in x 3in x 4in peice of T6-6061 high grade aluminum soon off ebay for $8. I will then make the mount out of that. I have no idea when Ill be able to order the ESC but the batts, pinions and chain should be ordered here soon aswell.
RIP- Tammy (9/14/08)
Takedown
Takedown's Avatar
Originally Posted by TexasSP View Post
So what, you're keeping the 5th scale now?!
and you just got your old warhead back!
I take back my earlier comments takedown, you change your mind more than a woman and must be some kind of new breed of human that has like XY chromosomes and the the several layers of female DNA mixed in..........
And yes I missed the warhead badly so I wanted it back.
Takedown
Takedown's Avatar
10.06.2008, 04:42 PM
This is a very long-winded build thread...
Thats what you get for being 17 in search of a job.
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.06.2008, 05:43 PM
I wouldn't say taboo as much as it is that he has done bad business with too many people in the past and charges way too much for his product. He has also not been very truthful or forthcoming in many areas.
www.cubicle101.com
Takedown
Takedown's Avatar
10.06.2008, 08:59 PM
Not to fond with FD's service...
Takedown
Takedown's Avatar
10.12.2008, 03:05 PM
Ok guys heres a long awaited update...
I might be going lipo with this project afterall- http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
I also got the motor put back toghther and installed onto my custom mount. Pics will be up later today.
10.12.2008, 04:02 PM
Lipo, yay! I'm assuming you're ordering 4 packs for a 10s 9800mah setup? 5s 9800mah or 10s 4900mah won't be enough in either configuration for that large/heavy of a truck...
Takedown
Takedown's Avatar
10.12.2008, 05:39 PM
Actually the 10s 4900mah setup will be plenty... Higher voltage ussually means less current draw so it will be fine.
Here are some pics of the motor mounted...
Takedown
Takedown's Avatar
10.12.2008, 05:40 PM
I will also be installing 2 more mounts of the same specs on the rear end of the can to keep it from swaying.
brushlessboy16
brushlessboy16's Avatar
10.12.2008, 05:41 PM
Looks good takedown i still think belt drive to the center drive would be better then chain..
Takedown
Takedown's Avatar
10.12.2008, 05:44 PM
Im afraid of belt drive. Ive seen them snap on scooters quite often. The reason I want to use chain is because I can get the very small beads and not take up space but yet have a very strong connection between the pinion and the center diff. And their is less room for meshing error with using chain. If you mess up the meshing on a belt you could strip the belt.
Krawlin
Got brushless?
Krawlin's Avatar
10.12.2008, 05:50 PM
1 word can describe that.
Beastly.
Looks awesome Ryan, should be one hell of a truck.
As far as belt vs. chain, I have to agree with Ryan, the chain would be better, would have a far more solid/crisp throttle feel than a belt, and would be stronger. And as the chain stretched, you could take links out as needed. Cant do that with a belt. Good luck, should turn out awesome.
Monster GT Conversion
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
