RC-Monster RC8T
11.03.2008, 10:36 PM
36-60-2000 if running on 4s lipo or 36-60-1600 for 5-6s lipo unless the 36-70-xxxx comes out before you order
roofles.
11.03.2008, 11:10 PM
I'm not going above 3S
I have some 2S 5000mAh Hard Cased LiPos 7.4V from TrueRC. Amazing stuff.
RC-Monster RC8T
11.03.2008, 11:19 PM
use 2 2s in series for 4s. Your esc will thank you! Higher voltage yields higher efficiency/lower temps. On 3s your drawing more current which equals more heat. Also on 3s to get some decent speed you'll need a higher kv which draws even more amps, thus more heat.
11.03.2008, 11:46 PM
An XL motor will not fit in an e-savage. I think 60mm or an L motor is as big as will fit. An XL motor is not a good idea either because as mentioned above its just too much power. I would go 4S, 2S on each side for weight distribution. A 3S setup will not work here because an e-savage is still a pretty heavy MT truck and you are going to be pulling too many amps.
roofles.
11.03.2008, 11:50 PM
Right, I won't be pulling 3S anytime soon... Have some 2S on hand, why not?
Have another question.
He's offering me $125 shipped if I buy tonight, that's the motor (9L), MM (Mamba Max), and a BEC!
Good deal/Not
11.03.2008, 11:51 PM
Thats a steal. 9L motor is perfect for E-savy IMO. I like the 10L personally but I'm sure you can gear up or down to compensate. What final speed are you looking for?
RC-Monster RC8T
11.03.2008, 11:52 PM
Do it! Thats not a horrible price, You can sell off the 9l and make a few bucks back and get a good motor
roofles.
11.04.2008, 12:12 AM
I'm not sure along the speed.
Something... speedier than the 700HOs.. I want this to be worth my while. ;)
If the 700HOs reach about 30mph, I'll be looking around 40mph? Yes, I know, no need to crush my dreams, I already did it myself. I doubt a 9L can do that.
Who knows?
What specific model Medusa should I be looking for?
RC-Monster RC8T
11.04.2008, 12:16 AM
36-60-2000-5mm shaft This will get you 40MPH easily on 4s
roofles.
11.04.2008, 12:25 AM
Fun.
How about this 9L? Along 35mph would you say?
Btw, just sent him the $125... I can't wait!
RC-Monster RC8T
11.04.2008, 12:28 AM
35 might be doable with a 9l without toasting it. I would say that at the very least you can get a little more speed, tons more torque, and longer run times versus the stock setup. Will you just be bashing or racing?
roofles.
11.04.2008, 12:32 AM
No racing on this end. Mainly bashing.
I do speed runs sometimes... Not often, about twice a run. And a speed run, is about 50m for me.
Then it's to the grass, and dirt. (I have this small weird 'garden', well not really, it's mostly weed, growing right on the line of my neighbor and I lawns... I sometimes just try and get through all the weeds, and the roses that pop up out of no where; more like rose stumps)
roofles.
11.04.2008, 12:38 AM
w00t. I just heard that he will be shipping priority mail, and if he ships out tomorrow, I should be getting everything on Thursday, IF he ships out tomorrow morning!
That is, if my calculations are correct. >_>
RC-Monster RC8T
11.04.2008, 12:39 AM
Well running in grass and weeds is going to put more strain on the setup. I actually found out that grass is our enemy! It puts one of the highest loads on the motor/esc. An 18t pinion will get you 35MPH, but for your typr of running you might want to step it down a touch. 17t = 33MPH, 16t = 31MPH with stock 66t spur. If you can get some different spur gears on there they are generaly cheaper than pinions and if you get a 17t pinion and a little smaller spur for a little extra speed and a bigger one when your mowing over rose bushes that would be ideal. If you don't have a choice of spurs I would still try the 17t and check temps and go from there.
That is also with a 5.8" tire, not sure what your running for tires
roofles.
11.04.2008, 12:55 AM
Running ERevo tires.
I'm only driving on lawn grass.. Which is about 1-2" cut.
Rose bushes = very rare.
Wht about the stock setup? :p
