Originally Posted by Pdelcast
The real problem with running 4mm plugs is that there isn't much margin for error -- You probably won't have any issues, but do you really want to risk it?
I'd suggest using a 5.5mm connector as a minimum.
+1. 4mm should work, but 5.5s will handle it much better. I use 5.5s on my 6XL, my 1515 1.5D, and my Medusa motors (when they get here) will get 5.5s on them. I've never had an issue with CC 5.5mm bullets even on the amp-hungry 1515 1.5D.
