Does anyone make a plastic spur for the crt.5? -
11.13.2008, 10:32 PM
Is the stock spur the same as an 1/8 scale...or does someone make a plastic one that will fit.. Metal on metal gears sounds awful...I know that it is a small thing, but........
11.13.2008, 10:41 PM
I did do this myself. I had to grind the teeth off the stock spur, and had a hpi 47t spur bored to slide over the diff cup. Then I bolted them together. I had to space the bulks up to allow the gear to clear the chassis as the spur is farther forward.
11.13.2008, 10:45 PM
A while ago there was a lot of discussion on this topic, and nobody was able to come up with an easy, 100% effective solution. If I recall correctly, a Kyosho spur can be modified to fit on the stock center diff (forgot who did this, though).
11.13.2008, 11:00 PM
If it is a PITA, I will just live with it...I just hate the sound that's all
11.13.2008, 11:04 PM
Believe me, I know. Driving a sub-1/10 truck at the 1/10 indoor offroad track that makes as much noise as a 1/8 buggy does get a bit annoying. Outside it was fine though.
RC-Monster Gold
11.13.2008, 11:08 PM
I tried it over a year ago when the .5 first released. Eventually scrapped the whole thing in my "do-over".
Monster Bottle Opener
11.14.2008, 12:04 AM
what about using plastic pinion gears?
I used a "bottom" line.
RC-Monster Gold
11.14.2008, 01:11 AM
Plastic will not last. There is a reason all the pinions and CBs made to mesh with metal spurs are hardened.
11.14.2008, 02:14 AM
i figured as much, but I saw these (the brass reinforced ones) and it got me wondering;
http://home.ptd.net/~kershawd/Kersha...inionsMod1.htm
11.14.2008, 11:05 AM
I had some of those left over from my brushed motor days. They did not work well with anything brushless... We easily ripped the teeth of them with a 9l on 3s in an emaxx.
11.14.2008, 11:22 AM
Originally Posted by lincpimp
We easily ripped the teeth of them .
well.....pimpin' aint easy.
lol, thanks for the heads up
11.14.2008, 11:24 AM
No prob...
