11.18.2005, 10:08 AM
Thanks Serum.
Should i just use one of the Li-savers wired in where i have the ubec(controller wires) or would it be better to use one per pack somehow?The FMAs i was going to use have one per pack.
I guess in series the packs are acting like a single 8s pack so one would be OK?
11.18.2005, 10:35 AM
Yes, one should be fine actually.
11.21.2005, 10:07 PM
question, would a 8000mah 3s2p lipo pack that discharges 10C be ok with the 9xl? that would be 80 amps max and it says 40-48 amps continuous. would this be ok?
11.21.2005, 10:31 PM
If it is a 10c continous it would be 80 amp continous. Which would be good.
Peace!
Country
Help support the
Rc-Monster
Buy here
11.21.2005, 10:51 PM
but its 10c max. i think it would be ok but i dont really know. also, what would happen if it was exceeded? or would it just not deliever the power?
11.21.2005, 11:18 PM
40amps cont. should be plenty for that motor. But 3s Lipo isn't enough voltage. You need 4s absolute minimum. I would consider 5s to be the minimum for usable purposes!
The lower C rate cells won't deliver the same voltage that the higher C rate ones will. Plain and simple, that is the main difference.
11.21.2005, 11:40 PM
well i was gonna run 2 in series. also, what kind of run times should i expect?
-corey
EDIT: what happens then the motor draws more than the lipo batteries can deliever?
11.22.2005, 12:37 AM
Others may be able to give you a better estimate on runtime than I could.
When a motor draws more from the battery is rated for, the voltage won't drop too low, unless it is for a long time. For RC car use, we will never see a Lipo drop low from a long burst, as long as the battery is being used properly. The worst thing that could happen would be that the LVC would kick in @ 3v/cell, which is why they are absolutely necessary.
Usually Lipos have a burst rating, and this is a burst rating for a period of time, usually 10secs.
11.22.2005, 09:20 AM
with gp 3700 18 cells 25 -30 min on a 9xl so on 8000 mah I would say about and hour.
Peace!
Country
Help support the
Rc-Monster
Buy here
11.22.2005, 12:57 PM
I would use a minimum of 4 cells as well. 5/6 is better. it is not about the mAh's only it's about the total available power.
