FG101C
12.27.2008, 02:33 PM
What about in the air though? Guess I'll go get it dirty if the track dries out today and report back.
FG101C
12.27.2008, 08:42 PM
Ok, went to the track. No nose diving, absolutley awesome motor. Perfect speed on 4s 6000mah geared 15/48, 20-21 minutes. Highest temp was 160 deg at the 20 minute mark.
Was thinking this would be awesome on 5s with a 13 tooth pinion, now to find a 5s that will fit under the body and yield a 20 minute run time.
pasan
I <3 RC
pasan's Avatar
12.27.2008, 11:39 PM
Toljaso :)
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
Medusa 80mm motor
transtalon
Medusa 80mm motor - 12.28.2008, 01:55 PM
So anybody tried running the Medusa 80mm 2000kv motor? Any good or bad things for this motor. I'll be putting this on the Lst2, maybe 6S on MMM V3. thanks.
FG101C
12.28.2008, 08:27 PM
Probably wrong thread but maybe someone with more knowledge and experience can answer this. What would be a more efficient motor, Medusa 60mm 2000kv or Tekno Neu 1515/1/Y/F (2200kv)? Medusa geared with a 15 tooth pinion, Neu with a 13 tooth pinion on 4s.
Unsullied_Spy
Unsullied_Spy's Avatar
12.28.2008, 11:06 PM
I run the 80mm in my Muggy and it's insane. You may have problems snapping tranny pins in the LST2, it is really powerful. It is definitely powerful, I'm going to gear mine down a bit to keep the amp draw down though. My MGM 16018 gets a little warm with this motor.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.28.2008, 11:31 PM
They are both pretty efficient motors. It depends on the vehicle as to what would be more efficient. The Neu 1515 series much bihher than a 60mm Medusa. That 60mm Medusa would prolly be more efficient in a buggy than the Neu, but in a truggy or MT the Neu would be more efficient because of it's larger size giving more torque to move a heavier vehicle.
FG101C
12.29.2008, 12:09 AM
Ok, thanks. I have ran about five packs on the Medusa and love it. Now to find a 5s that will give me 20 minutes and fit under the D8 body. I'm thinking the Hyperion 4350mah would be enough, but not sure. My Polyquest 4s 6000mah gives exactly 20 minutes.
80mm Medusa
transtalon
80mm Medusa - 12.29.2008, 02:03 AM
Thanks for the info unsullied Spy. I have a 1527 1D 2200kv Neu but have problems with ESC burning up, Now I bought a 22418 MGM but I'd like to put a MMM and the 80 mm Medusa in it.
Unsullied_Spy
12.29.2008, 02:57 AM
No prob. 1Ds typically pull a lot of amps. It's best to go as low of KV as you can and run higher voltage. Your ESC will handle 6s, so a 1600KV would be best. The 2000KV motor is fine, but the 1600 will run cooler and pull fewer amps. I had a 1515 1.5D in my Muggy and it pulled a ton of amps, I could thermal my 16018 in just a few minutes if I pushed it hard enough.
cdis
12.29.2008, 07:58 AM
What sort of amps are we talking about, for the 2000kv 80mm medusa on 6s? I've got one of those ordered, but I'm going for longer run times, not crazy insane speed, so should I see if Medusa can change it to a 1600kv?
Unsullied_Spy
12.29.2008, 08:08 AM
Anyone feel like getting me an EagleTree or Oracle as a belated Christmas gift?
I'm not sure exactly how many amps, and it all depends on your gearing (you pull a lot more with taller gearing). If you would prefer longer run times the 1600KV would be a better option. I wish I had ordered it instead, but I got the 2,000 so I'm just going to deal with it. It's not bad or anything, but the 1600 would be better (I'm currently stuck with 4s lipo, so it's kinda a good thing I got the 2000).
cdis
12.29.2008, 08:52 AM
Yea, I'm in the same boat. I was going to run 5S LiPos which is why I initially ordered the 2000kv, but having read up I think I'll get a bunch of 3s 4000/5000mah packs and run 6s packs.
sikeston34m
sikeston34m's Avatar
12.29.2008, 09:16 AM
I've been looking at the Oracle System.
How is it compared to other data loggers?
Where can I see a screen shot of the software? Thanks
Unsullied_Spy
12.29.2008, 09:20 AM
http://medusaproducts.com/oracle/index.htm
Specs are good, I think they're comparable to a EagleTree. I've heard that the resolution is really good on them, better than an EagleTree. Not sure where to find a screenshot of the software.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
