Live Fast, Die Early
01.02.2009, 08:30 PM
alright thanks.
01.02.2009, 09:40 PM
kershaw has more 6mm pinions available now 15, 16, 18, 20, 24, 25, 30, 32 http://home.ptd.net/~kershawd/Kersha...ns/Pinions.htm in case anyone was wondering.
01.02.2009, 09:59 PM
Originally Posted by TwzteD
Anybody Know Anything About The Emaxx Tranny Conversion? Is It Good? i think it would be a little bit easier to make a motor mount and maybe run 2 packs on the side of the chassis?. Probably Cheaper.
 My LST with Emaxx tranny amd G-Maxx conversion. Toss plastic gear and go with an aluminum one. If you decide not to go with the KB45 motor think about this setup.
01.02.2009, 10:13 PM
thanks for the pic but i wanna keep the kb45 its a good motor for its price, im gonna stick with the stock trans.
01.02.2009, 11:54 PM
Well i sent an email to TDR and that motor mount is a no go i told him itneeded to be 30mm spacing and m4 threads and he wrote. so back to square one.
"Steve Kenney"
Add sender to Contacts
To:
umiraceing@yahoo.com
Sorry man,,
That is an uncommon bolt spacing and it will not fit my motor mount.
Duder
www.tdracingrc.com
Something, anything, nothing
01.03.2009, 12:16 AM
Why not look into one of the medusa 70 or 80mm motors? A little more money but well worth it.
01.03.2009, 01:21 AM
Those are 32p, you need mod1 gears to mesh with the stock spurs...
01.03.2009, 01:00 PM
linc do you still have a picture of your custom e lst motor mount?
01.03.2009, 03:19 PM
I will have to find it and take a pic when I go to work today... I will make a note to remember!
01.03.2009, 04:50 PM
WARNING: May become violent.
01.03.2009, 04:59 PM
Nice mount linc.
RIP- Tammy (9/14/08)
01.03.2009, 05:22 PM
Originally Posted by Takedown
Nice mount linc.
Thanks, but I need to round all the edges and whip up a support for the rear of the motor. Since I will be using a hacker c50 xl motor I may just make another L bracket to bolt to the rear of the can and attach on top of the current bracket.
And I really need to polish it up, looks kinda ratty... Never really finished it while it was on the lst cause I had the tdr mount on order.
01.03.2009, 05:34 PM
yea thanks for the pic, btw do you think if i ran anything lower than a 24t pinion on the kb 8xl, will it get to hot? i do plan on making my own mount and see how that turns out. ill probably shave the shaft to 5mm also so i ill be able to use mikes mod 1's this way i got more of a variety, im worried about having the motor hit the transmission with a smaller pinion because it will need to be in closer.
does the kb45 xl motors fit that mount?
01.04.2009, 03:17 AM
Hmm I Have A maxamps 3s 8000 lipo and i saw one for 150$ never used i may pick it up and run them in series for 6s 8000mah if i cant get them to fit up front if not maby in front one in back? what do you think. Better than the zippy?
01.04.2009, 03:39 AM
Hmm, gonna be heavy...
And you need to change your avatar, that was my old avatar and someone bitched about it so I changed it. Not to sound petty, but if I can't use it neither can anyone else...
It is funny, and alot of people did like it here, I changed it because I did not want to offend anyone... in that way
