Well I hope those tires from tower aren't what your planning on running! Those are for a Monster Truck, they're 5.5" tall vs. 3.5" stock on the CRT.5. I wouldn't have picked the vileneon system, but to each his own. You could have gotten a sidewinder and a feigao L motor for about the same. You will be needing a battery tray, Mike makes some nice ones, and a Mod1 pinion and a bore reducer to mount it to the vileneon motor both the pinion and reducer are available from RC-Monster. Prolly a 14-15 tooth if your gonna stick with the stock size tire, if you go to a 1/10 truck tire a 13-14 tooth. That will put you in the high 30's for speed, not sure how the temps will be on the motor with that gearing though, I'd start low and if temps are ok go up a bit but not much
That won't work! 32p is Mod.8 You need MOD1. Best place to get them is RC-Monster. All the MOD1 pinions I have ever seen are for a 5mm motor shaft and the vileneon is a 1/8" shaft so you will need a bore reducer as well
I got a question about tower... I ordered 3 pinions and a traxxas female connector... but my question is can i take out the connector and just send back the pinions or do i have to send it all back?
