Originally Posted by FG101C
I can't seem to get the 60mm 2000kv to run cool on 5s (pushing 190+), but on 4s, geared 15/50 the buggy rocks. Still a bit warmer than I like, 170 ish, but my timing is at Low (5), will set it to Lowest (0) and try again. 100% punch control, lowest start power setting, some curve in the throttle.
Every good motor that's pushing some power is going to give off some heat.
For example:
Let's take 1000 watt motor that's 90% efficient. This means that all the time it's at the 1000 watt level (WOT) it's going to "bleed off" 100 watts of heat.
Running a smooth can motor with no heat sinking doesn't leave that heat much place to go. So, it builds up.
I've been having great success with the 36-60-2000kv in an E Revo gearing 18/52.
I'm using the Novak Heat Sink with it on 4S. I really believe I could run this all day long with no heat issues at all.
50 degrees outside and I can barely detect any heat at all coming from the motor.
If you have room, give it a try.
I do intend to try this on 5S AND on 6S. This will be the real test!
