Need help keeping motor from moving...
pumpkinfish
Question Need help keeping motor from moving... - 01.05.2009, 12:39 AM
Hi guys. I had major issues with my MBX6 conversion today. In two different heats, the motor moved away from the spur enough to not make contact and I had to abort the run. I managed to get one good run, then it moved during the warm up lap for the main and I had a DNF.
I am running a Medusa motor with Mike's Mugen mount. When I had my 777 with the RCPD mount, I never had a motor move. I have tried blue loctite on the screws and that didn't help much either. It is always my top screw working loose and then the motor pivots away. I am wondering if there is a screw with serrations or a lock washer I can get into the groove of Mike's mount. I actually liked the RCPD mount in that the whole face was flat and I could use different headed screws. It seems like Mike's is made for cap heads only.
Please help me as I want to finish a race!!!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.05.2009, 12:45 AM
Use a star washer behind the head of the screw. With that you should never have an issue!
George16
Supermaxx
George16's Avatar
01.05.2009, 12:50 AM
If not, you can also use a lock washer in addition to blue loctite.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
pumpkinfish
01.05.2009, 01:07 AM
Star washer? Never heard that term before.
George16
Supermaxx
George16's Avatar
01.05.2009, 01:11 AM
Star washer:
http://www.circlipindia.com/star-washer.html
Lock washer:
Revo with OS .18TZ
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.05.2009, 01:17 AM
Thanks for the examples George, lot easier than explaining
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.05.2009, 01:48 AM
Are you using cap-had screws now? Honestly, you are #1 that I have heard of with this problem. Maybe the threads in that particular hole are worn out(?). Try rotating the motor to the next set and see if you still have a problem. I do find it hard to believe threadlock didn't help. Did you let it cure before the run?
pumpkinfish
01.05.2009, 10:11 AM
Yes I let it cure and I am using cap heads. I bought brand new screws just becuase it was a new build. The problem with the Medusa cans is the holes are closer together if I rotate the can and they will not line up. I could do that with a Neu, but not a Medusa.
I may have to go back to my Neu to see if that does the same thing. I tried this Medusa just to see how it compared to my Neu plus it was more efficient than the 1512/2D I was running.
George16
Supermaxx
George16's Avatar
01.05.2009, 10:14 AM
I never had problems with my screws loosening. But for added insurance, I use lockwasher with blue loctite to ensure they don't loosen up.
Revo with OS .18TZ
01.05.2009, 10:51 AM
In the two 50mm Medusas I have, there are two sets of mounting holes; the typical 25mm spacing, and a set that are narrower-spaced.
What's_nitro?
01.05.2009, 08:13 PM
Have you tried the RED threadlock??? Make sure the socket is in good shape on the screw or you might not get it out.
rchippie
rchippie's Avatar
01.06.2009, 03:17 PM
I would advice against using red locktite . It will stick very very well & make it tough if not impossible get the screw back out . If you do this & the screw wont come out . ?Take your soldering iron put it the highest setting & touch the screw for a minute or so . you should know be able to back the screw out .
REAL MEN RUN BRUSHLESS
Shark413
Shark413's Avatar
01.06.2009, 05:28 PM
You mean something like this? The block on the motor mount has a 4mm screw that is used to hold the motor from moving away from the spur. It worked great, but once I moved up to a better motor (Neu which allowed me to tighten the motor mount screws tight enough to prevent the motor from moving( I no longer needed it. The Feigao's use softer aluminum and you couldn't really tighten the screws to much without fear of stripping them out.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
big greg
01.06.2009, 05:39 PM
out of 10 medusas ive seen run, 9 of them had thread problems. the aluminum/taps they use are crap. i usually just tap them to a bigger size right away, i have 6/32's in the motor im running now, and they loosen up after a race, not to bad tho
What's_nitro?
01.06.2009, 06:54 PM
That's very interesting- that it could be a design flaw with the Medusa motors. If so, I hope it's fixed soon because I have been looking into their motors.
