01.21.2009, 03:30 PM
It uses two bearings in the wheel to hold the front wheel on and spins more easily.
Also "beefier"...
Thomas P
01.21.2009, 03:51 PM
perfect, mailed the store owner, and hope he can change it :)
  Send a message via MSN to Thomas P
Thomas P
01.23.2009, 01:05 AM
Can someone help me with this
Wheelbase: Super extended chassi =?
What kind of bodys will fit? E-maxx,T-Maxx,Revo? etc ?
What 30 series rims will fit ? I have some issiues to understand exakt what Proline wrights in the text for thoose rims.
Thomas P
01.26.2009, 02:00 PM
decided to use the Losi XXX-T CR shocks..(since i use Losi shocks on my competition 4wd buggy) i have tons of rebuildstuff etc @home and all springs etc, and oils...
SOMe more parts..
2 x TRA3614 Traxxas Body Mounts $8.58
2 x PRO1074-00 Pro-Line Masher 2000 2.2" M2 Truck Tires (2) $30.98
1 x TRA3678 Traxxas Wheelie Bar Assembly $12.75
1 x LOSA5013 Team Losi Shock Mount Bushings (All XXX) $3.39
1 x LOSA5150 Team Losi Shock Springs 2.5" x 2.3 Rate (Pink) (2) $3.39
1 x LOSA5082 Team Losi 4" Threaded Rock Crawler Shock Set (4) $52.99
1 x PRO2686-01 Pro-Line Agitator 2.2" Chrome Rear Wheels (Jato, Rustler, Stampede) $9.99
1 x PRO2685-01 Pro-Line Agitator 2.2" Chrome Front Wheels (Jato, Rustler, Stampede) $9.99
1 x TRA5552 Traxxas Slipper Clutch Rebuild Kit (Jato) $6.79
2 x TRA2388X Traxxas Planetary Gear Diff (VXL) $25.50
2 x PTK-5004 ProTek R/C T-Style Ultra Plugs (2 Male/2 Female) $9.98
1 x CSEMMBMAX-CMS7700 Castle Creations Mamba Max 1/10th Scale Brushless Car Package (7700kV) $212.99
4 x TRA4686 Traxxas 48P Spur Gear (86T) $10.36
DuraTrax Bearing Set Rustler/Stampede/Bandit (14) 1 19.99
RPM Bumper Wide Front Blue Rustler/Stampede 1 6.69
Pro-Line 30 Series Wabash Wheels Chrome Stampede/Rustlr 1 20.19
Pro-Line 30 Series Dirt Hawg M2 Front/Rear Tire 2 33.98
Pro-Line '72 Chevy C10 Pick-Up Body Stampede 1 22.99
Unsullied_Spy
Unsullied_Spy's Avatar
01.26.2009, 02:15 PM
Originally Posted by Thomas P View Post
A Q:
30 Series rims from Proline, can they be used on this truck? if so, is there anything extra that will be neded to useém ? like HEx or so..
30 Series wheels/tires will work just fine. If you keep the stop front end go with 2 pairs of rear wheels, or get front and rear if you convert to the nitro-style spindle setup. I've got 30 series Badlands on my Rustler and they are awesome, very good tires.
Thomas P
01.31.2009, 01:19 AM
Ok, sounds nice...mailed and tried to PM T.Arnold about rodlength for steering, but without any succes :(. It seems that i have to build the car first,then order rods..
My Amain order arrives Tuesday (UPS called me yesterday) rc-monster, not sure, maybe this week, then :D:D....Tower still missing, maybe this week, kind of imported my bearingkit is in that one.
Thomas P
01.31.2009, 01:31 AM
Q: Did see that they offer 17 and 23mm hex for Stampede...any idea how truggy wheels/rims will look on this car ?
what tire/rim series/size can be used with thoose hex? i mean a 40 series arnt they REAL big?
Unsullied_Spy
01.31.2009, 02:53 AM
I'd use Buggy wheels on the Stampede. Truggy wheels and tires will really hard on parts. 40 Series tires are for 1/8th scale only, they're very large and very heavy.
Thomas P
01.31.2009, 03:05 AM
Thanx Unsullied :)
Unsullied_Spy
01.31.2009, 03:11 AM
No prob. Get the steel output yokes, at least 1 spare diff, a few driveshafts, and plenty of spare stub axles. Traxxas had a good design ~15 years ago but it's a bit weak for modern power and bigger tires.
Thomas P
01.31.2009, 03:28 AM
Since i bought the CVDs from rc-monster dont the steel Output Yokes come with that kit?
I got one extra spare VXL diff besides the one that i will mount
"Stub axles"..hmm not sure what this is :(
Unsullied_Spy
01.31.2009, 03:39 AM
If you've got the CVDs you should be fine. An extra diff is good to keep handy with large, heavy tires. The stock diff is fine for most use but if you're putting down enough power and/or using large enough tires there are several ways the stock diff can fail. I wouldn't worry about stub axles if you've got the CVDs, The ones that come with the kit should be plenty strong enough.
Thomas P
01.31.2009, 03:43 AM
Thanks Unsullied again :D. About the 17 and 23mm hex just a thought, im gonna run the 30 series Dirthawgs and Mashers 2000 only.. :) hopefully they will be a little more gentle to the tranny then bigger other tires ?, or should i stick to "stock regular 2.2 tires"
Thomas P
01.31.2009, 04:27 AM
Ohh, i missed, what Ballstuds can be used? regular 4/40 like AE ? any links wold be great to the ones that fit
01.31.2009, 11:20 AM
Ahh just saw you 7700KV motor - you want the 4600 or ideally just by a mm and buy a medusa 50mm 3300.
