Adding a Low ESR Capacitor to a Series Connector
sikeston34m
sikeston34m's Avatar
Adding a Low ESR Capacitor to a Series Connector - 03.02.2009, 09:50 PM
I'm always looking for new ways to improve my E Revo.
The Capacitor used is a Low ESR 2700uf 25v version.
I decided to give the this a shot and see if it helps. (It surely can't hurt)
The heat shrink used is single wall with hot melt glue inside. I like the way it grips the connector AND the capacitor. It should be sturdy enough to survive.
It will mostly be used on 4S, but I have ran this cap on 6S with great results.
traxxasbasher13
03.04.2009, 12:09 AM
Cool, does it work ok. I always put capacitors as close to the esc as possible.
sikeston34m
03.04.2009, 12:44 AM
Yes it works ok. I tried it today. The Monster is smooth as butter anyways, so it's hard to tell any difference in that department.
I always go as close as I can too, but the only thing between this and the ESC is the 10Ga. wire, so it should help.
