mod 1 pinion . bore ????
notatoy
notatoy's Avatar
mod 1 pinion . bore ???? - 03.17.2009, 02:55 PM
hi guys i need some help i am doing a nitro conversion , now the motor i have has a 3.17 mm shaft . i know i need a mod 1 pinion question is these pinions are 5mm bore so will i need a reducer ???? if so can some one tell me the one i need . oh and what would be the best tooth count for a 1/10 scale running a 3900kv motor .any help appreciated guys thanks in advance ..
Jeremy1976
03.17.2009, 03:07 PM
Here is the bore reducer. Drop down screen/arrow will give you two options to choose from. http://www.rc-monster.com/proddetail...rod=RCMreducer
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.17.2009, 03:47 PM
BTW 3.17mm is 1/8", so you would need the 5mm to 1/8" reducer. Just in case you were wondering....
03.17.2009, 03:49 PM
We need more info to give you gearing recommendations.
Info such as vehicle make and model, battery specs, tire height, motor info, intended useage, mph desires, etc. Pictures are good too, especially of hot chicks. (this last part will not help with the gearing situation, but why not?)
notatoy
notatoy's Avatar
03.17.2009, 03:50 PM
thanks the drop down box shows 2 sizes mmm, witch on is the needed for this motor shaft also any help on the tooth count would be appreciated , thanks again ..sorry if iam being thick here .lol.. iam pretty much new to brushles systems ,,,
notatoy
notatoy's Avatar
03.17.2009, 03:51 PM
ohh scrubb that lol guys your all amazing on this site love you all ohh i understand you need more info it will be used of road . not after a speed demon just some fun here it is ..http://www.blacksmithproducts.co.uk/...d=RC_NITROKING
notatoy
notatoy's Avatar
03.17.2009, 04:08 PM
and this is the system i have to be fitted ,, yes i know its not a mamba max .lol..http://cgi.ebay.co.uk/ws/eBayISAPI.d...ayphotohosting
notatoy
notatoy's Avatar
03.17.2009, 05:31 PM
mmm . no gearing reccomendatoins ????? BATTERIES WILL BE USING FOR THE MOMENT nimh 9.6 volt untill the 2 cell lipo comes ,,
03.17.2009, 06:23 PM
Model Specs:
Length: 453mm
Width: 320mm
Height: 183mm
Weight: 2.5 kg / 5lbs
Wheelbase: 305mm
Ground Clearance: 25mm
Wheel Diameter: 100*51mm
Nice lightweight vehicle it seems, and the rollcage is interesting.
I would think the motor/esc combo will work alright, but I'd prefer an 80amp item myself for a bit more headroom. I dunno what the kv rating on that thing is though- 10turns doesnt mean much to me....
03.17.2009, 06:28 PM
Gearing will depend on the kv rating of the motor, now we know the voltages and tyre diameters. Not sure what spurs that thing uses, but Im sure something from a kyosho or similar 1/8 scale vehicle will fit. The ratio is listed for diffs, ony says 1/8 scale, but I'd guess 43/13 probably.
notatoy
notatoy's Avatar
03.18.2009, 05:07 AM
hey neil the motor kv rating is 3900kv... i will check the spur today hopefully that will be enough imformation to reccomend a pinion of correct tooth count ,
