ESC Brushless comparo feedback ratings good bad
SpeedAssault
SpeedAssault's Avatar
ESC Brushless comparo feedback ratings good bad - 03.18.2009, 06:34 PM
IS there A School here to learn all about the Options on Brushless ESC's ?
And the Sensor or Sensorless and what all the different Lipo types are and what does it mean ?
I'd like to Define the top 5 ESC's
IF not, Can we create a data base here with SIMPLE Easy to read Guide?
If the following info is a duplicate please let me know where it is.
The Focus on this thread is to find out where each Brushless ESC sits on a scale 1 to 10, 10 being the best overall Amp, voltage, programmability and so on.
I am in the market for a 6S to 10s Lipo and brushless capable ESC to power my 1/5 scale rally project--.it weights 9 lbs with motor. and want 60 mph.
Bear with me I am still finding new info, so if there is something missed or incorrect , please let me know So I can edit the original.
LEt's start of with what ESC's there are to choose from:
Tekin RX8
MGM
Castle Mamba Monster
TMM
Losi XceLorin
Any others ?
MGM 12032
Up to 10S lipo
120 amp
Tekin- Been in market a long time and has great products
New RX8
6s Lipo
Sensor /sensorless
Let me know what what's popular and what you like and Do not like ?
and I will add them in as we go
Thank you
Rian
03.18.2009, 07:39 PM
RC-Monster is the Encyclopedia Brushless- read everything....
Nah, I have a few FAQs and Tutorials in my sig that explain the different types of escs and BL motors, plus the different types of lithium batteries in great detail, but with plain English language and explanations.
There are also a multitude of other FAQs that are stickied in the General and Brushless sections, with even more info and explanations.
As for whats best, it depends much on your personal needs/desires, and budget; looking at similar builds to your own will yield usual info too.
The thread below lists peoples personal setups with various vehicles, with info on gearing and such to make life easier:
http://www.rc-monster.com/forum/showthread.php?t=6423
Given the vast number of options out there, its a bit unrealistic to compile a list of escs, lipos, motors etc etc, but if you look at BrianG's calculator, it lists most of the popular motors that we tend to use.
On the esc front, 99% of whats easily available is 4-6s lipo at most, with only the $$$$ Schulzes and MGMs going higher in voltage; exception is Lutach's LT-10s esc. A 9lb vehicle should do fine on 6s lipo though, even if it is a stretched maxx.
SpeedAssault
03.18.2009, 09:41 PM
Hey thank u suicid
I'll look at the FAQ stickies
I found this battery but it does not say what # lipo ? ? ? So do I just pay a attention to volts and amps ?
25c/50c 18.5 volt 5000mah Lipoly Battery pack
Made from super powerful 2500mah cells, Factory rated for 25c continuous and 50c burst discharge capability. a whopping 350 amps burst on this pack
Capacity - 5000mah
Voltage 18.5v
Cont. discharge - 25c(125amps)
discharge - 50c(250 amps)
Your sig link "Brushless, lipo & LVC tutorials" No worky
Thank you
I am thinking a MMM but I dont know the importance of sensored ESC's
SV6000
SV6000's Avatar
03.19.2009, 08:40 AM
There are some threads on this forum about people converting 1/5 scale cars to brushless and using quite large motors. To control these people have used a wide variety of ESC's, ranging from Schulze, MGM, Castle MMM and Kontronic. However some speedys are more suited to some motors than others. For example my MMM did not like to run my Plettenberg Maxximum motor.
Another option that people are doing is using large boat speedy's and running mechanical brakes, eg a Neu 2200 series motor and castle hydra 240 speed controller with the original mechanical brake for a baja.
You just need to do your research and use the search button lots and lots, follow the links in threads. Spend a day just doing research and seeing whats out there and figuring out what people like and don't like. And ask lots of questions.
03.19.2009, 11:18 AM
Link fixed.
With lipos, each cell is 3.7v nominal, so 18.5v / 3.7 = 5s. Fully charged voltage is 4.2v per cell.
Sensored escs are good for crawling at very low rpms (where as a sensorless design will have issues reading the back emf signals from the motor as it needs a certain number of rpms), or for multi-pole outrunner motors used in a direct-to-diff drive system for example; in the vast majority of cases, you dont need a sensored setup, plus the only good ones are Novak (under powered if you want to go faster than ~35-40mph), or the Tekin RX8 (expensive as its aimed at racers, and only 2 motors available).
I would look in the 1/8 scale onroad think tank thread and read the whole thing- basically the same kinda cars as what you're building, only they are 1/8 to start with, rather than being stretched.
Dunno what you mean about needing a front diff though? Your emaxx has a front and rear diff, and would work best with a centerdiff unit bolted to the middle of the chassis in place of the tranny, just like a typical 1/8 conversion done using one of Mike's centerdiff motor mounts.
SpeedAssault
03.22.2009, 11:00 PM
Thank you
Can you direct me to a thread,
Search only works so far
03.23.2009, 06:33 PM
The BL and General sections are the best place to look- just have to look through all the pages until you find stuff thats relevent - researching for yourself will probably be quicker.
