Originally Posted by asheck
Did you try to turn the lvc off? What about your connectors? If you have a bad solder joint or something, perhaps that is messing with the voltage readings the esc is seeing.
No we did not try to turn off the LVC. Connections on the traxxas connector are fine. I know his ESC was kind of acting up though it seemed. At one point he could not turn it off with the button. Another time he could not get it to turn on.
