Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.01.2009, 10:02 PM
I was just going to replace the diff braces in my GTP... If I can find some with a similar bolt pattern it would be nice, otherwise a little drilling doesn't bother me. Does anyone have an idea what would be a suitable replacement?
04.01.2009, 10:05 PM
Post up the hole spacing but maybe close to ofna lx
What's_nitro?
04.01.2009, 10:20 PM
The front is 18mm wide, the rear is 11mm, and the holes are centered L/R. *Edit* Would this bearing work? It's 6mm wide, is that extra 2mm going to be a problem or is there a need for lateral shimming?
04.01.2009, 10:26 PM
Easier to just get these.
http://www.nitrohouse.com/catalog/pr...oducts_id=8915
What's_nitro?
04.01.2009, 10:31 PM
Are those 5mm width? Do you know the end-to-end length of the slipperential (inside the bearings)? I swear I've seen it mentioned but I cant find it again...
E-Maxx Sweden
04.07.2009, 06:44 PM
Mike
I just don't want to be a pain in the...., but
Do you think you will have the mount for the FLM 3905 E-maxx chassi in this summer?
Best Regards
Mikael
Sweden
Fits XT8!
Dafni
Dafni's Avatar
Fits XT8! - 04.08.2009, 01:41 PM
The slipperential fits the XRay XT8 truck perfectly, no mods required at all, direct drop-in (mikes chassis brace installed)
lydiasdad
04.08.2009, 11:54 PM
i just destroyed the stock tranny in my twin force. I think I am going to try and install this in there. I will post the results. Any foreseen problems?
Forgefeu
04.09.2009, 04:59 AM
Cool, it is a good news for me. I ordered one.
Now just to wait the rx8
strodedawg
04.09.2009, 08:21 AM
just installed mine in a rc8t and street tested it.......niiiiiiiice!!!!!!!!!!!!!!!!!!
can't wait fir practice this weekend
let's build something sick!
superek4
superek4's Avatar
04.09.2009, 10:26 PM
Anyone race with it in a jamming CRT x1?any review?:)
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
jhautz
jhautz's Avatar
04.14.2009, 01:59 AM
I have been trying to figure out how to get shorter outdrives on the slipperential because they hit the steering servo mount in my 808. Mike mentioned that he thought the HB outdrives might work, but I ust tried them and they didnt. They work on the small cover side, but not on the large cover side. Its just a little to tight to get the cross pin in the hole. Strange that it works on one side but not the other.
What I did make work was the xray diff outdrives, but I had to replace all of the gears inside with the xray gears to make the outdrives work because it uses a different size cross pin thru the outdrive shaft for putting the crown gear on. It also needed to have a bunch of extra shims added to make it work.
I used all of the metal washers/shims that came with the slipperential, and then used all of the washers/shims that were in the xray diff too. So basically 2 shims behind each of the 4 satelite gears (1 xray washer and one slipperential washer) and then I put both of the xray washers that go behind the 2 larger crown gears behind the crown gear that went on the small slipperential cover side allong with the washer from the slipperential. (1 slipperential washer behind the crown gear inside the large cover, 2 xray washers and 1 slipperential washer behind the crown gear on the small cover side) I hope all of that makes sense. It seems to be a perfect smooth mesh now. I tried adding more washers to see when it got to tight and if I put more than this in there anywhere the mesh got to tight inside.
Heres a quick pic with the shorter xray diff outdrives and the xray internal gears installed. I think it should be good. Not exactly a cheap change to get shorter diff cups, but if you already have an xray then you have all of the parts from the xray diff to make the change. In the 808 you basically need the shorter outdrives because if you use the longer ones the outdrive hits the steering servo mount and you need to take quite a bit off just make enough clearance.
Anyway, just though Id post what I found to work.
Xray outdrives insatlled with xray gears shimmed up. Slipperential outdrives sitting next to it for length comparison.
to make it...
or break it...
Silent...But Deadly
E-Maxx Sweden
04.21.2009, 01:18 PM
Mike, do you have any schedule on when you can have a bracket for the 3905 FLM chassis to work with the Slipperential
Best Regards
E-Maxx Sweden
alangsam
04.21.2009, 02:13 PM
or for the 3905 stock chassis?
yuri
yuri's Avatar
04.25.2009, 04:46 PM
Thanks a lot for the info!
My Brushless X-Ray XB808:
LT-6S-150
Neu 1515/2.5d/S
Zippy-H 6s 4000mAh
