Ofna GTP build
Big House
Big House's Avatar
Ofna GTP build - 04.21.2009, 07:42 PM
I just picked up a new Ofna GTP and it is time to build. I am looking to run either a Medusa 36/70 2300Kv with the MMM or the 2200kv MMM combo. I am going for nitro enbarrising fast but with drivability. Let me know your suggestions.
04.21.2009, 08:12 PM
the mmm 2200 combo on 5s should do the trick
04.21.2009, 08:34 PM
cant beat the combo
Big House
Big House's Avatar
04.21.2009, 09:10 PM
Why not on 6? I have two 3S1P packs. Now all I have to do is get the the carbon fiber chassis, shock towers, stiffening plates and other pieces cut and I will be good to go. Throw in rear pillow balls to increase handling tuning, CVD's all around, and foams on all four corners...that should yield me one nice beastly monster of a racer.
bdebde
That's All Folks!
bdebde's Avatar
04.21.2009, 09:42 PM
I would do the MMM 2200 combo on 6s... literally; I have a GTP with RCM mount and Castle 2200 motor and some 6s batts, all I need is another ESC to get it going (could steal one from another rig I suppose). Still need to paint the body too.
phatmonk
RC carbon junkie
phatmonk's Avatar
04.21.2009, 09:54 PM
Here is what I have so far.Its a freakin monster.I am running 3s with a Neu 1515.5y 4400kv.This car is only 9.5 lbs so it never overheats and its a blast to drive.Really fast and ya gotta run foam tires.The rubber tires arent balanced as well.Get the hardened steel ring gears for the front and rear diffs.Have fun
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
04.22.2009, 10:50 AM
[threadjack] Phatmonk where did you get the .5y motor? [/threadjack]
04.22.2009, 11:23 AM
Yeah, the stock tires are crap IMO. They balloon and the foam gets all bunched up in one spot. This happened on my GTP and the tires ended up ripping apart the fender area behind the rear set. It is a fun car to drive though, even on "only" 5s, and that's on a 1512 motor; I can't imagine the tire spin on a 1515 motor.
phatmonk
RC carbon junkie
phatmonk's Avatar
04.22.2009, 06:59 PM
threadjack BLREVO Offshore hobby threadjack
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.22.2009, 08:00 PM
I don't need to imagine it. I know first-hand.
Throw a 1515/1y in there on 6s geared 20/51 and you'll see what I mean.
Big House
Big House's Avatar
04.22.2009, 11:00 PM
Monk,
Where did you get the carbon chassis? I am thinking about cutting one myself, but if i can get on CNC'ed i would go that route.
04.23.2009, 12:13 AM
lol, No thanks, it's bad enough on 5s and a 1512 motor...
The build continues...
Big House
Big House's Avatar
The build continues... - 05.13.2009, 11:09 PM
Finally got the beast out of the box and first impressions...weight loss...she got to lose some weight and I have to sure up the chassis. While I am waiting to get the cash to by a 12x24 sheet of 4.4mm CF, I took some 1/8 Cf and fashioned and front to center to rear brace. I also cut out the servo tray using the same CF. I mocked up the positions of the battery tray and motor mount. By the way the Tekno Motor mount is as sweet as they come. I don't inticipate any chassis flex. More to come....
Name:	motor mount small.jpg
ID:	6987   Click image for larger version
Name:	Brace shot small.jpg
ID:	6988   Click image for larger version
Name:	full brace shot.jpg
What's_nitro?
05.14.2009, 12:00 AM
Looking sweet man. Nice work on the CF pieces.
nitrostarter
nitrostarter's Avatar
05.14.2009, 12:15 AM
What are the options for beefing up the GTP's diffs?
N. Rustler conversion
