Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
jnev
jnev's Avatar
04.28.2009, 06:22 PM
Hopefully you haven't updated it yet. I am looking for the Losi MRC ratios right now...
Edit: Copy and pasted from RC-Driver:
The internal transmission ratio is 7.59:1. With the stock 60 tooth spur gear and 14 tooth pinion, the transmission has an overall ratio of 32.5:1. The ring and pinion in each axle have a ratio of about 2.64:1. This gives the Mini Rock Crawler an overall ratio of 85.96:1.
04.28.2009, 06:24 PM
Nope, no updates until I get the data requested in this post. I usually post my intent to update and wait a couple/few days for the responses. Seems to limit the late requests...
04.28.2009, 06:58 PM
OK, I really don't want to download the PDF and figure this out. So could you list all the gears used for each speed?
LST 1st gear: ?
LST 2nd gear: ?
List the gear pairs like so: output/input, output/input, etc. Similar to how I have the revo tranny listed in the calc. That would be the most helpful to make sure I have the right data.
And yeah, I'll add the Mod1.5
Ok lets start with the external 2 speed. Not sure if you will add that info (guess the spur sizes could go in the "spur section" under Lst)?
1st - 70/18
2nd - 63/25
Now here are the internal ratios:
LST FOC (this is the losi kit, also the internals of the aftershock are the same as this) - 23/22 primary 30/15 secondary
The Lst and Lst2 have a manually selectable high/low internal gearing, all other lst based trucks have the FOC listed above.
Lst/Lst2 low range internal gearing - 30/15 primary 30/15 secondary
Lst/Lst2 high range internal gearing - 23/22 primary 30/15 secondary
Also your "swap mod" info is correct.
I am sure no one care about the ratios for the mech reverse, so I will not bother looking them up.
NoControl
NoControl's Avatar
05.18.2009, 09:58 PM
Question brian or anybody for that fact.
On a tc5 the fron and rear diffs are 40t the 2 pulleyes atached to the spur are 20t. Would I be correct in assuming the calc inputs should look like
F\r diffs: 2/1
Tranny: 1
add gear ratio: 1
spur: 80 (stock gear)
pinnion: 30 (since thats what I ordered)
Battery: 7.2v 6s 1.2 (since I don't have any 2s lipos yet)
motor: 5400 ( 7.5 novak drift motor)
wheels: 2.5
Not sure what the rest of the optional data is value wise.
brushlessboy16
brushlessboy16's Avatar
05.18.2009, 11:02 PM
So whens the update comin?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.18.2009, 11:05 PM
F\r diffs: 2/1
Tranny: 1
add gear ratio: 1
wheels: 2.5
That looks right to me. You only have two ratios to deal with. The 2:1, and your pinion/spur ratio. Everything else would be 1:1.
NoControl
NoControl's Avatar
05.19.2009, 09:38 PM
Thanks nitro.
06.10.2009, 11:29 PM
OK, I finally made an update:
- Added several brushed motors.
- Fixed LST/LST2 transmission ratios.
- Added LST/LST2 FOC transmission ratio.
- Added Hot Bodies D8 differential ratio.
- Added a note for the old RCM slipperential stating V1 is discontinued.
- Added Mod 1.5 gear pitch.
- Added Losi MRC transmission ratio.
- Removed battery charger data table, selection box, and all code relating to pre-set battery charger information.
- Added new feature to the Power Calculator page. Once the user enters the data into the form and calculates the power figures, it will also provide a table listing estimated pack capacities to get the same runtime at different voltages.
- Removed the Sky & Technologies link (Quark) since the address is no longer active.
- Removed the Beta alert on the BL Parameter Comparison page.
SnoopMaxx
SnoopMaxx's Avatar
06.16.2009, 07:13 PM
Lot of updates
I have a 775 Titan Motor in my 3906
Do I use the 10T brushed 6526 Kv rating ?
105.35 mph (169.23 km/h)
The Titan 775 is closer to 1300 Kv I think
Morten SnoopMaxx
Never to old to play
c",)
whitrzac
Can't catch this...
whitrzac's Avatar
06.16.2009, 11:46 PM
any chance you could add the novak/speed passion "1/8" motors??
and the basic ROAR leagl ones too...
06.17.2009, 10:17 PM
Originally Posted by SnoopMaxx View Post
Lot of updates
I'm not sure. Those brushed motors were added by request and I believe they are normal 540 size. Most likely, a larger motor with the same turn count will have a lower kv, but exactly what, I don't know.
:sigh: Lol, I did ask everyone for any other suggestions so that the update would include everything. But every time I post an update, there's always one more thing.
I generally shy away from adding just any motor. This site is not affiliated with RCM, but it IS meant for the members here, so I try to stick with what Mike had. Besides, the motor list is getting VERY long. At some point, it will become very cumbersome. But, if demand is high enough, I guess I could add Novak stuff. Post things like kv, size, etc and I'll add them.
whitrzac
Can't catch this...
whitrzac's Avatar
06.17.2009, 10:32 PM
size turn watts KV wight shaft WORTHLESS INFO
HV4.53524Sensored5504.58905,0008.365mmLargeHigh / HighS
Y
YYYBlackRibbed
HV5.53525Sensored5505.58003,7008.365mmLargeHigh / HighS
Y
YYYBlackRibbed
HV6.53526Sensored5506.57303,4008.365mmLargeHigh / HighS
Y
YYYBlackRibbed
HV7.53526Sensored5507.56203,0008.365mmLargeHigh / HighS
Kcaz25
Kcaz25's Avatar
06.17.2009, 10:34 PM
I don't use Novak anymore but I do use your site Brian and I appreciate every thing you do.
whitrzac
Can't catch this...
whitrzac's Avatar
06.17.2009, 10:46 PM
I prefer not to, but they do make nice motors for a mid size conversion
06.17.2009, 10:49 PM
Y
YYYBlackRibbed
Y
YYYBlackRibbed
Y
YYYBlackRibbed
Thanks, I'll put that in my next update...
No problem! And thanks!
For the price, a 60mm or 70mm Medusa is better IMO.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
