WANTED BADLY: Need Bearings - Look!
rawfuls
roofles.
rawfuls's Avatar
WANTED BADLY: Need Bearings - Look! - 05.13.2009, 04:38 PM
Need the following badly for my Revo/Maxx axle carriers:
  • 4 Axle Bearings 6 x 13 x 4mm (5180)
  • 4 Axle Bearings 12 x 18 x 4mm (5120)
If you have any, or know anywhere where they're quite cheap, PM ME!
05.13.2009, 05:20 PM
Try ebay?
5180: http://shop.ebay.com/?_from=R40&_trk...All-Categories
5120: http://shop.ebay.com/items/_W0QQ_dmp...5180&_osacat=0
redshift
RC-Monster Square Tube
redshift's Avatar
05.13.2009, 05:39 PM
Had good luck with www.Bocabearings.com recently. 99 cents each. Fast shipping too.
rawfuls
roofles.
rawfuls's Avatar
05.13.2009, 06:09 PM
I saw ebay, but I don't wanna pay 6 bucks for two bearings =/ Or is that how much they usually cost.
Grr
rawfuls
roofles.
rawfuls's Avatar
05.13.2009, 06:36 PM
Hmm, I can't find them on BocaBearings..
05.13.2009, 07:03 PM
Heres a good price on 10 of the second set you wanted: http://cgi.ebay.com/Ball-Bearing-YB6...3286.m20.l1116
redshift
redshift's Avatar
05.13.2009, 07:10 PM
Avidrc.com has the 12 x 16, and 6 x 13 x 5, 1 buck each. You can run standard 6 x 12 x 4's with the reducer sleeve, I have no idea why Traxxas did that, 6 x 13 is not a standard size. You can try Amain, Acer and vxb.com also if you need more options.
While you are waiting for your new bearings, try this- take a sharp X acto blade and gently get under the edge of the seals on your bad bearings and pry them up. Blast them out with a high solvent and turn them a few times until the debris is clear, I use oil instead of grease, anything between 30 and 90 weight should be fine. Once you do a few they are easy, and in a pinch you'll be able to run them when you can't wait for replacements.
rawfuls
roofles.
rawfuls's Avatar
05.13.2009, 07:11 PM
Oh looky here.
http://cgi.ebay.com/New-Traxxas-16-8...3%3A1|294%3A30
Damnit I'm dumb..
Thanks guys, if I don't win the auction I'll try doing redshift's way.
shizzon
shizzon's Avatar
05.13.2009, 07:52 PM
I just replaced all of the bearing ins my E-revo with Ceramics and kept all the old ones, there yours if you pay postage (there is one missing axle bearing as it exploded, that was the excuse for me getting the Acer's!.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
05.14.2009, 11:19 PM
In case anyone needs more bearings : http://cgi.ebay.com/NEW-TRAXXAS-SLAY...3%3A7|294%3A30
rawfuls
roofles.
rawfuls's Avatar
05.14.2009, 11:21 PM
Sweet, thanks Linc, now I have a link incase I can't Shizzon doesn't have the right bearings (He said one exploded, and if it's the larger one, then I'll need to shop around, but if the smaller bearing exploded, I can use the old bearings from the old knuckles, I'll just need the oversized (larger) bearings)
