Originally Posted by Semi Pro
looks great james
makes me want to fire up my carbon 8ight before it's finished and go to the track
how do you like the Fioroni flexers?
yeah, technically my 8ight isnt done either but i couldnt wait so i used servo tape to hold the battery down so i could test it today. all i am waiting on is the lipo tray from RCM. be sure to post some pics/vid of yours when its ready.
as far as the Fioroni flex braces i LOVE them but be careful to run them with carbon chassis. when i first put them on i knew immediately that there was too much flex and that the carbon could break given the right hit. so the first week at the track with them on i drove really easy and everything went fine. i did a comparison with the flex allowed and then locked it up (you can lock the Fioroni brace so it acts like a normal aluminum chassis brace) and the handling was so much better with the flex. it was night and day. much easier to control and much more stable. and it was just absolutely "popping" on the jumps. had an almost spongey feel to it.
so this week i ordered some washers that i could fit on the flex brace and increase the tension on the spring so that it couldnt travel as far. my intention was to do this enough to allow some flex still but not so much as to risk cracking or breaking the carbon. when i finished i thought to myself "i should add a few more washers in there" cuz it still had lots of flex. but i was in a hurry and left to the track. needless to say i snapped the rear end of my chassis on a big tumble. no worries though. i have several carbon chassis' for my rc8t in the garage.
i am still going to run the flex braces but i am going to put more washers in them so that the flex is minimal. i actually have both my 8ight and RC8T setup now with composite brace up front and the flex brace in the rear. i am going to set them so they have about 1/8" of travel allowed. i had about 1/4" allowed when it broke.
so there is my 2cents. i know you are building that carbon 8ight with that expensive Matrix chassis so the Fioroni's are great but just get some washers and dial down the flex. btw, the inside diameter you want for the washers is 6mm. i found some on amain that said 6mm id. but they were actually like 5.5 when i got them so i used my dremel and reamed them out slightly.
for aluminum the flex braces would be awesome i bet. alum. isnt going to break for sure and i dont think there is enough flex that it would get bent so i think these would be a sweet upgrade on any alum. chassis. they make the biggest difference over rough terrain and jumps.
