New Turnigy stuff at hobbycity
Metallover
RC-Monster Spudgunner
Metallover's Avatar
New Turnigy stuff at hobbycity - 06.01.2009, 12:44 PM
As the usual hobbycity spokesperson, I feel obliged to point out the new stuff at hobby city. I logged in, clicked on new products, and found a page filled with turnigy lipos. They are even cheaper then flightmax packs. A 6s1p 25c 5000mah pack is only $85 as the flightmax equivalent is $100.
The highest c rating on the packs is 25c,,, There are 3,4,5, and 6s 5000mah packs. The 3s is $43, $56, $75, $85 for 6s.... There is also a 3s 5000mah 15c pack for under $35. wow.
A polyquest Pack is new to that I'm excited about. It's the 1600mah 2s pack. It's the best pack for the vendetta series if you're into that kind of thing...
I think this is the same thing has the hobbywing stuff
Turnigy Brushless Car Power System 2350Kv/150A
An extremely powerful brushless system for any 1/5 or 1/8 scale truck, car or buggy.
Equiped with cooling fan and a large surge ESC, this system will greatly increase the power output of any standard or brushed system.
ESC Spec.
Continuous Current: 150A
Burst Current: 1080A
Resistance: 0.0002ohm
Suitable Car: 1/5, 1/8 on and off road.
Battery: 2-6 cells Lipo (6-18 cells NI-xx)
BEC output: 5.75V/3A switch mode buit-in
Motor type: Sensorless and sensored brushless motors
Dimension: 68 x 55 x 45mm
Weight: 150g
Motor Spec.
Model: 3674SL V2.0
Kv: 2350
Scale: 1:8
Max Current: 76Amp
Turns: 9T
Weight: 363g
Diameter: 36mm
Length: 76mm
Shaft length: 15mm
Shaft Diameter: 5mm
Contents:
ESC: 1 x 150A
Motor: 1 x 3674SL (2350Kv) with Cooling Unit
Pinion Gear: 21T
Turnigy Programming Card
Price $149.95 --- Already out of stock
nitrostarter
nitrostarter's Avatar
06.01.2009, 01:00 PM
I really like the ginormaous fans on both Motor and ESC.
I do like the prices on Zippy packs. And the prices go down down down as you buy more from them and climb up there ladder of points system.
N. Rustler conversion
whitrzac
Can't catch this...
whitrzac's Avatar
06.01.2009, 01:10 PM
are the batts any good??? unlike their NiMh...
06.01.2009, 01:13 PM
Bleh, fans...
Hmm. The motor is a 9T eh? Must be a 2 poler considering the kv spec. It has the same physical length of an XL motor, but a 7T XL has a kv of 2380, while this motor has almost the same kv at 9T. That means the coils must be a tad shorter than a Feigao XL.
Metallover
Metallover's Avatar
I would guess zippy quality on the batteries but I'm not sure. No one has tried them yet.
nitrostarter
06.01.2009, 01:14 PM
You may be talking about those "Tenergy" Nimhs that are total crap. Turnigy is a different brand.
But the Zippy, Rhino, Flightmaxx packs are all good batteries. Keep the temps down and they'll push and last!
whitrzac
Can't catch this...
whitrzac's Avatar
06.01.2009, 01:15 PM
nitrostarter
06.01.2009, 01:17 PM
The Turnigy packs look like repacked lower C Flightmax packs to me.
06.01.2009, 01:21 PM
Bleh, fans...
So the motor will perform as well as a feigao xl, with slightly less torque. Good for a buggy, but not as good as the castle system. I will stick to MMM escs and the 2200 motors when they will fit the kv requirements, or go with neu motors otherwise.
nitrostarter
06.01.2009, 01:24 PM
I love these specs:
ESC Spec.
Weight: 150g
I don't know of any 1/5's that I would bother wasting my money on this for...
But it should do fine in buggies and lighter MT's
06.01.2009, 01:25 PM
I am sure it will move a 1/5 scale car fine, IF you gear for 25mph!!!
06.01.2009, 01:27 PM
Or have a 2-3 speed tranny...
nitrostarter
... and then 35mph max...
06.01.2009, 01:31 PM
I bet you could squeeze out 40mph with a 3 speed. Might want to get some bigger fans though...
Rebelgium
06.02.2009, 11:55 AM
I've read about those EZrun ESC's, and the 150A on seems like an extremely good deal.
If I had a roller, I'd buy the EZrun 150A and a Neu motor.
The motor in the kit is not so good though, I wouldn't go over 40k RPM because I've read the rotor cracks if reved higher.
And that ESC looks exactly like the EZrun 150A. Exactly the same specs to, I would be verry surprised if it isn't the same one.
I hope they'll sell the ESC separatly :p!
