larger hub carriers for emaxx -
12.30.2005, 11:34 PM
I haven't had a problem on the few runs i've had with my new emaxx exept for the right front wheel nut coming off ( luckily i was going slow and was able to find it ) but was wondering if what i heard was correct about the bearings being undersized and if it would cause a serious enough problem to buy larger carriers? thanks.:C:
The reason the nut is coming off is because the axle that it is screwed on spins and the nut can slip and un-screw itself out, it has nothing to do with the bearing or hub carriers. Use some blue loctite and that should fix the problem.
