My Lx One
saucisse
saucisse's Avatar
My Lx One - 06.26.2009, 09:52 PM
Got an Lx One real cheap so decided to convert it to BL.
I used a second steering brace mounted on steering posts to make the rear of the buggy more stiff.
I used to Hyper9e battery tray (which is good to hold up to 5s packs)
I used the Traxxas mount to install the Mamba Monster ESC on a Plexiglas plate.
Need to find a better way to locate the receiver's antenna.
Motor is the 2200kv with 15t pinion (stock spur is 48t ??) running on Zippy's 4s 25c 5000mah after 10min the ESC was at 115f, lipo pack was at 95f and motor at 155f ( too hot for me) Should I go with a bigger pinion (16t) to have the motor running cooler ??
Any comments/suggestions are welcome.
____________________________________________
I don't suffer from insanity, I enjoy every minute of it !!
06.26.2009, 10:50 PM
Very nice layout
e-mike
e-mike's Avatar
06.26.2009, 10:51 PM
cer chaud pomal pour un 2200 dans un buggy
ter surement undergeared je dirais que cest surement ca car dans mes e-revo a 33 celcius en 6 cell gearer pour 41mph jpogne 137 sul moteur en 28 min....112 esc et 110 les lipo
tes diff tienne le coup???messemble que tavait tout vendu???
D8t on juice!!
saucisse
saucisse's Avatar
06.27.2009, 09:01 AM
J'vais essayer avec une 16t au lieu de 15 pour voir...yes les diffs tiennent le coup mais ça craque quand je freine hard
06.27.2009, 12:53 PM
That does look very nice. I like the layout as well but the steering upper plate on the back of the truck threw me off for a minute.
saucisse
saucisse's Avatar
06.27.2009, 01:34 PM
I'll change it later on for one of the original color.
legend15x3
07.21.2009, 09:57 AM
Like the layout.
Just wonder if have a problem with nose diving off jumps? I have an LX1 also with ezrun150 and workig on a new motor since the last one the motor screws stripped. I am also running the nylon spur which is a 51 tooth and 13t pinion. Also, i fear my motor mount is bent forward after a hard crash that stripped the screws.
Did you need to space the motor mount up for the spur you run?
himalaya
himalaya's Avatar
07.21.2009, 11:43 AM
H9e battery tray! How did you get it fit? drilled extra holes in the chassis and countersunk them?
....What a Blue Sky....
saucisse
saucisse's Avatar
07.29.2009, 11:03 AM
Originally Posted by legend15x3 View Post
Like the layout.
I don't have any nose diving at all. I'm currently running with the stock metal spur gear and no needs to space the motor mount.
saucisse
saucisse's Avatar
07.29.2009, 11:04 AM
Yo got it!! Drill and countersunk
legend15x3
07.30.2009, 10:15 AM
So weird that i have the nosing over problem, I have my gear and batteries located to the rear of the car and it gets a great bit of drive. I had to use a spacer for the nylon spur to fit properly in my lx1 but had to space the motor plate in my ultra so that it would all line up and not bind.
saucisse
saucisse's Avatar
07.30.2009, 10:26 AM
Are you using drag brake? If yes this might be the problem
