Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
08.11.2009, 01:08 AM
That looks F*ckin awesome James!!!!
kulangflow
Never Fast Enough
kulangflow's Avatar
08.11.2009, 09:13 AM
Let me know when it's done so we can head out to do some action video of it. Excellent work as always!
brushlessboy16
brushlessboy16's Avatar
08.11.2009, 09:22 AM
Wow, thats astounding- very nice! now get it running and take vid...
nitrostarter
nitrostarter's Avatar
08.11.2009, 09:57 AM
The motor mount looks sick! I was wondering how you were going to do it. It looks just like the Tekno stuff, which is a great way of mounting the motor. I would say to make sure the chassis doesn't flex so the gear mesh remains the same.
Looks great!!
N. Rustler conversion
emaxxnitro
emaxxnitro's Avatar
08.11.2009, 10:04 AM
wow its really coming together
808E
Ryu James
Ryu James's Avatar
08.11.2009, 12:31 PM
Looks great!!
i have thought this also so i have an idea for eliminating too much chassis flex. i will be working on it this weekend hopefully.
Jammin SCRT10 Neu 1512 1y
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.11.2009, 02:34 PM
Looks beautiful man..!
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
lutach
lutach's Avatar
08.11.2009, 02:54 PM
Awesome....When do you think it'll be up and running?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.11.2009, 02:56 PM
Beautiful, simply beautiful.
I am anxious to see this thing running, and on some jumps too!
KaztheMinotaur
KaztheMinotaur's Avatar
08.11.2009, 09:39 PM
My pinion came with out a set screw also. I will have to call them tomorrow.
Ryu James
Ryu James's Avatar
08.11.2009, 10:01 PM
yeah i have already gone through calling them and jumping through hoops. just to save you some time what you need to do is email Deloris Miller at dmiller@sdp-si.com and explain what happened. give her part # and order #. i just got a reply form her today saying the engineer or something is checking things further. hopefully they will just get me another gear sent, even though i have already tapped the gear they sent now.
KaztheMinotaur
08.12.2009, 06:53 AM
This sucks. They changed their web site. The hub & set screw option isn't offered now. I hope they changed it in the last day or so since you contacted them.
How deep of a hole did you have machined out of the gear? I think it needs to be 4mm deep to have enough of the shaft sticking out the other side to fit on the bearing.
I'm going to a machine shop this morning.
What size set screw did you use in the pinion?
KaztheMinotaur
08.12.2009, 09:15 AM
I think we are going to be SOL...
Her reply to my email was that the website "had" and error and has since been corrected.
Ryu James
Ryu James's Avatar
08.12.2009, 10:03 AM
i had 6mm machined out of the spur gear. 6mm is ideal cuz it allows the shaft to protrude far enough through to sinc up to the bearing right but also leaves 1mm of space between gear and bearing so it freely spins. 6mm worked perfect imo. you could go 7mm and then have 3mm thickness which is same as stock and then take off 1-2mm of the entire gear so the gear is only like 8mm thick instead of 10mm. this would shed weight but cost more.
as for the pinion i used a 6mm set screw. if your machinist is like mine and doesnt have metric stuff tell him to drill a 3/16" hole in the pinion for a set screw and then the 6mm tap works perfect.
i have been using this guide for my own tapping and drilling. your machinist will have the same type of chart.
http://www.imperialinc.com/pdf/I_Tap&DieChart.pdf
Ryu James
Ryu James's Avatar
08.12.2009, 10:08 AM
hmm, initial reply i got was engineer was checking and now havent heard back still. but if she said that i agree. just have to drill and tap your self like i did i guess. mine turned out fine. doesnt look factory but it will work. and actually it is soooo close a fit with the 12/40 that i think i am gonna end up using like 15/40 instead. i hope temps are ok this route.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
