Well i dont change batterys much, so it does work perfectly for me, it can be done also with clips or something like that.
Top deck is removable, its hold down with screws, there is thin rubber sheet betwene battery and topdeck so it basicly pushes battery against tray. Tray is made specialy for these batterys so only empty space is at both ends where rubber sheets are now placed.
Well i am 50% finished my tray but i'm a bit worried about the balance of the truggy. I have the motor mounted the right rear side of the chassis and the battery the front left side....Would it be better the have the battery mounted opposite the motor up the rear end?
I was thinking the same thing I wish I had a pic of my current setup but imagine a long rhino pack(I think it's like 174mm) and a the motor on the back right hand corner.
Here's an older pic:
i would make a tray and space it up from the chassis, drill and tap holes in the chassis, so you can secure the MMM with zip ties to, it will come undone like that for sure
Balance should be ok with motor (right rear) and battery (front left).truggies tend to lift the front wheels up,and go nose up over jumps.I'd leave it and see if it suits the way you drive it.
