mmm fan always on ?
Rivermaxx
mmm fan always on ? - 10.11.2009, 06:08 PM
Shouldnt this fan turn off at some point. Or is there a possible issue? I just hooked up my 2 6s 3300mah 30c batts in parrallel and the fan doesnt seem to turn off.
YogyBrushless
10.11.2009, 06:11 PM
The fan should only be on for a few sec when armed, then off until temps hit 140f. i had this happen to me when the throttle channel was reversed, check and c if that is the case.
but if ur vehicle is running fine it might be something else.
__________________________________
Must Find Cash For RC
Rivermaxx
10.11.2009, 06:29 PM
Yes it seems to be running fine.The radio is setup right. This is for my speed project and actually dont mind it being on all the time but I just want to make sure nothings wrong with the MMM.
Freezebyte
10.11.2009, 06:49 PM
If its on all the time, then something is wrong. Fan temp sensor is bad or your overheating or the ESC has a fault. Contact Castle
Rivermaxx
10.11.2009, 06:59 PM
Any Ideas?
F7Rider
10.11.2009, 07:27 PM
If your running a v1 the fan stays on.
Rivermaxx
10.11.2009, 07:34 PM
I dont think its a v1 because the power wires are soldered on the board and the bullets are on the motorside. I opened it up to clean the dirt out of it and the build date sticker says is november of 2008 also . Pretty sure v3's were out by then.
