Riko
Riko's Avatar
11.20.2009, 06:32 AM
Originally Posted by Unsullied_Spy View Post
MMP + Larger motor = Bad when used in the wrong setup, in 1/8th setups I'd use it only on 6s with lower KV motors when your peak power output is less than 2,000 watts (keep the amps down).
MMM + Small motor = OK. Small motor + big truck = bad. You won't hurt a motor or ESC by using an overkill ESC.
okay, thx dude!
You've been hit by, you've been struck by a smooth criminal
  Send a message via MSN to Riko
ravin
ravin's Avatar
11.20.2009, 08:51 AM
How long is the 1518?
E-revo mmm 1518 6s
Rustler mmp novak crawler(17.5 stator) 6s
Slash 4x4 1512 1800 mmp 6s
E-maxx 1350kv mmp 6s
Summit VXL
Stampede 4x4 Rx8 1400 mmp 6s
asheck
11.20.2009, 09:04 AM
So is there any chance of a 60mmish motor based on your smaller motors? I really like the 2 pole motors for smaller applications, where the higher torque is not needed. A fancy little sensor plug could be handy also, :) but not really necessary.
11.20.2009, 06:49 PM
Originally Posted by PdelCast
Here you go...
From left to right -- 1520 / 1Y / 1500Kv -- 1518 / 1Y / 1800Kv -- 1512 / 1.5Y / 1800Kv -- 1717 / 1Y / 1580Kv
Huzzar...
LiqrSicc
LiqrSicc's Avatar
11.20.2009, 07:10 PM
WHOA what's the max voltage on that 1518?
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
Unsullied_Spy
Unsullied_Spy's Avatar
11.20.2009, 07:16 PM
I imagine that at 1800 KV it would be 5/6s for normal use and up to 8s for more extreme use.
new setup
spcpicard
new setup - 11.20.2009, 07:19 PM
Here's a pic of my new light weight setup, I'll be racing it this weekend to try it out. It comes in at 6lbs and 11.9ozs with out the body. I'm running a 1450kv 1509 tekno neu on 6cell 2500mah packs. With this same setup I can get 14 mins with the Mamba Monster esc. I'll see how it does with the MMax pro.
ravin
ravin's Avatar
11.20.2009, 09:36 PM
Huzzar...
I must be missing something ...I don't see how long it is (in mm) will it fit a E-Revo?
E-revo mmm 1518 6s
Summit VXL
11.21.2009, 11:41 AM
Ah- imagination required, sorry.
It should fit just fine, may just have to fettle the rear shock tower a little for clearance. The 1518 is only about 3-5mm longer than the 1515 based on the comparsion of the 1520/1518/1512 in the photo above- if you take a look at the birdseye views of the BL erevo you get a good idea of how much space is available- one of the little brace thingies might need a notch cut into it, but nothing drastic realy:
http://www.traxxas.com/products/elec...op-chassis.jpg
Im sure dimensions will be posted when the new motors are put up for sale in the next few days or so- check the CC website at that time.
