Originally Posted by redshift
The preheat temps don't need to be any higher than 100F, or 38C, and should not be allowed to drop much below about 80F, or 26C.
This was my recommendation for
running temps, I guess I should have been clearer.
There is no consensus as of yet on what is too cold. That will vary brand to brand, and also vary according to C rating. It's pretty much wrap them in some sort of insulation, or take your chances.
It may be a good idea to over-gear some for cold weather running, that way the batts will likely generate more of their own heat. With so much tirespinning, the load is naturally
lower, so that may also work against you.
On the flipside, if you're running in slop, then over-gearing may be bad, because loading up the wheels will then present
more of a load than normal.
There's no simple set of rules for this stuff, other than personal intuition.
Just watching pack temps is your best bet, and I strongly advise against letting temps drop much below ROOM temp--- just so I can avoid the damn C vs F conversions....
Anyone else has more info, please chime in. I am NOT an authority on this stuff!
Just passing on the best info I can.
Hope maybe that helps!
