Originally Posted by ozmonster
These Turnigy 4500mAh 2S2P Pack are little bit too thick for me, 25mm...are there any 6,6V packs under 23-24mm?
Can these packs be charged using A123 Sonic charger?
Not that I know of (r/c spec ones at any rate), and not easily.
You'd need a lower capacity pack to make it thinner, but the majority of whats on the market currently all seem to be the same 2250mah packs- paralleled to make 4500mah. Lutach would be the guy to talk to as he's trialling various new packs, but they wont be in general circulation for a while; will have to go lipo or see if you can enlarge your battery trays some how.
As for the charger, you will need to make an adaptor for the balance taps as the hobbycity packs use the common jst-xh ( align ) style plugs, where as the A123 charger has its own weird little setup and different wiring configuration- you may be better off with just picking up a cheap (sub ~$50) charger with a built-in powersupply and balancer- look up the Thunder AC6 for a good example.
