01.02.2010, 09:41 AM
There have been many threads dedicated to the removal of threaded fastners. A quick search on here should turn up a handful of threads detailing how to do this, please in the future try searching. Since this thread is already here, the easiest way is to use a dremel tool with a cut off wheel. Simply cut the pinion off! HAHA no seriously now use a cutoff wheel and make a slot in the setscrew and use a regular screwdriver to remove it. If you have used loktite this will be more difficult but it can still be done. Once you make a slot with the wheel you can use a small butane torch lighter to heat up the pinion slightly, the heat softens the loktite and it should back out.
Welcome to RC-Monster
