Summit with MMPro or Tekin RX8
kulangflow
Never Fast Enough
kulangflow's Avatar
Summit with MMPro or Tekin RX8 - 02.15.2010, 02:39 PM
Howdy Folks,
I've done a bit of research on the subject, but I'd like to go ahead and ask the great minds at RC-M.
Project: Traxxas Summit
Batteries: 4s lipo
Primary Usage:
-Primarily trailing (hiking the mountains) and pseudo-crawling (I have purpose-built crawlers for dedicated crawling needs.)
Secondary Usage:
-It'd be nice to have a bit of speed (~30 mph) for the occasional jaunt between rocky places.
The stock set-up is great for trailing and pseudo-crawling, but I'd like to have a little more speed in second gear. I do not want to gear up at all and lose any of the slow-crawling capability. I ran a MMM/Neu 1515 1y for a bit, which was great for speed, but wasn't quite there for crawling.
I'm considering a sensored brushless system. There are many people who are using the Tekin RX8, but I haven't found anyone yet using the CC MMPro with a sensored motor.
Questions:
-Will the MMPro be adequate, or would I be better off with the Tekin RX8.
-Is there another ESC that might work better than those two that I'm not yet considering?
-For brushless crawling in first gear, what do you think would be a good kV to shoot for? I'm thinking something in the 1500kV range as an all-around choice.
Thoughts?
Thanks in advance for any advice!
Brian
whitrzac
Can't catch this...
whitrzac's Avatar
02.15.2010, 06:05 PM
I don't think the BEC in the MMp would handle all of the servos that the summit has...
you might want to look into somthing like a Kershaw or dewalt motor.
nitrostarter
nitrostarter's Avatar
02.15.2010, 06:10 PM
I would use the MMP and use an external BEC or Rx pack.
N. Rustler conversion
02.15.2010, 06:28 PM
The MMpro would likely handle the motor fine since it is geared for ~30mph tops, but as said, the BEC might be the limiting factor. I personally would go the safer route and opt for the Tekin; not only will it handle higher gearing better, the BEC is a bit more robust.
whitrzac
Can't catch this...
whitrzac's Avatar
02.15.2010, 09:19 PM
...compleatly voiding the reason to get a MMp
nitrostarter
02.16.2010, 09:12 AM
I like to run Rx packs anyways, less work for the ESC to do is always better.
captain harlock
RC-Monster Captain
captain harlock's Avatar
02.16.2010, 09:57 AM
Bigger is better, my friend.
Nice to meet you!
kulangflow
Never Fast Enough
kulangflow's Avatar
02.16.2010, 02:15 PM
Thanks for all the advice!
I went ahead and purchased doo540's Tekin RX8 with the 1350kV motor. I'll let you know how it works out in the Summit.
Thanks again!
nitrostarter
02.16.2010, 10:11 PM
Will you be running 6s or 4s?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.16.2010, 10:37 PM
Thanks again!
Glad you got it ! Save's me some money, I was thinking pretty hard about it.
With 4s (or higher) It'll be what you want and need and more !
kulangflow
Never Fast Enough
kulangflow's Avatar
02.17.2010, 10:54 AM
I'll be running 4s primarily. If that's not getting the job done, I'll move up to 5 or 6s.
4xFord
02.18.2010, 01:21 AM
Please let us know how it does in it.
