Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
kazuaki
02.17.2010, 11:28 PM
I ran my Slash 4x4 (MMM/2650/4s) in the sand dunes this weekend. It was a blast for a while. But the rear paddles and possibly too tight slipper destroyed my rear half shafts. I need something that will hold up better. The Losi 8ight shocks worked awesome though!!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.18.2010, 12:08 AM
Did you want to know about the rx box or the esc?
Yes pleeze
Was curious what guys are using for a RX box w/a M.M.M. install ?
kazuaki
02.18.2010, 12:10 AM
Yes pleeze
I installed the Rustler/Stampede RX box and didn't like it. As you can see from my pics, I'm running naked now
pinkpanda3310
pinkpanda3310's Avatar
02.18.2010, 11:05 AM
Yes pleeze
Aah, my bad, it's a space thing isn't it?
erevo15151y
02.18.2010, 05:37 PM
thanks for the info guys, i put it together last night with a mamba pro,found out it wouldnt work on 3s only 2s,i called cc there customer service is great,sending me another one,so i slapped the monster on it until i get the pro,i stuffed it between the rx box and motor,its a neu 1512 1.5d/f on 2s.3s,4s,ill try to put some videos on youtube later,,,,
Name:	feb 2010 001.jpg
ID:	8550   Click image for larger version
Name:	feb 2010 003.jpg
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.18.2010, 05:43 PM
looks good, curious to see the video.
erevo15151y
02.18.2010, 06:27 PM
i have some goofy vids at www.youtube.com/giagi26101 i think that link will work,ill get some of the slash a soon as i can
02.18.2010, 06:36 PM
Man, I don't care how tight your slipper is, if you're running in sand and snap axles your axles are weak. I hate slippers and I hate weak drivetrains. Poopy deal.
02.18.2010, 06:57 PM
Just out of curiosity; are you running the center diff in there? Because running a solid center with dissimilar diameter tires can place a lot of stress on the drivetrain in general. But that's probably not why the rear shaft snapped; that's probably caused by the greater traction of those paddles. CVDs would help that a lot. I've never been a fan of the smaller slider shafts; they are just too weak to handle serious power IMO.
erevo15151y
02.18.2010, 06:58 PM
pinion is mod 8 pitch 32,what is a good cool running gear ratio/ i have a 18t on there now stock spur,1512 1.5d thanks,..
kazuaki
02.19.2010, 02:43 PM
No center diff, the thing would be useless with only rear paddles and a center diff. Can you say Front Wheel Drive? I was aware of the issues with different tire diameters, but I figured it wouldn't matter much in the soft sand. I mean worse case, the truck has to spin the fronts a bit faster, which shouldn't be too hard. You should have seen the truck after the back end broke. I tried driving it as a front wheel drive for a minute. Hilarious...
phatmonk
RC carbon junkie
phatmonk's Avatar
02.21.2010, 11:02 AM
Here is what I have done so far.I have tried it on 4s and its awesome.WOT is not advised!I have been driving it on 2s and it is a blast.I plan to put in a alloy Motor mount and swaybars.Checked my diffs and shimmed when needed.Shimmed the axels behind the hex adapter,tightened all loose screws.The radio box does crowd the steering servo wire though.I will end up notching it.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
02.24.2010, 11:34 AM
has anyone heard a date yet for cvd's?
Eflite Blade 400 heli on 3s
Shark413
Shark413's Avatar
02.24.2010, 06:17 PM
In case you missed it here is a thread I posted on the Traxxas forum.
It won't make your truck faster or stronger but this optional Traxxas part is very cool. It is the optional clear gear cover and besides looking cool, it allows you to see if there are rocks, dirt, etc. in your pinion/spur gears. I have sealed both ends of the driveline (heat shrink on the driveshaft, plugged the water drain holes and the foam plug for the diff hole but still dirt, sand and rocks get into the gears. Now I can take a quick look and see if I need to get in there and clean out the junk.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Overdriven
Destroyer of Tires
Overdriven's Avatar
02.24.2010, 06:19 PM
FLM has 4X4 specific CVD's availible now. Slash 2x4 cvd's can be adapted if you grind the diff cups down to prevent binding when the suspension is fully extended. Traxxas hasn't announced the release date of theirs yet, that I've heard anyway.
