Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
gixxer
gixxer's Avatar
02.24.2010, 01:55 AM
Originally Posted by Shark413 View Post
Gixxer, you won't be disappointed. I own both a Slash PE 4x4 and the Jammin SCRT10. I normally take both of them to track and run them equally, but this past weekend I ran 7 packs thru my Jammin and 2 thru the Slash (and one of those was by a local Slash 2wd racer who wanted to try the Slash 4x4 out). The Jammin is just so much easier to drive fast, handling is better and surprisingly it has proven very durable. I have had both of these trucks since late Dec and breakage so far:
Jammin = Popped one steering ballend off (no damage just popped it back on). Two rear wheel bearings were getting gritty so I replaced them.
Slash = Broke one outdrive yoke, broke two axles and bent two others, center diff bearing lost all grease (replaced).
I have raced my slash since they first came out. So far one broken arm. 2 rear axles replaced. Ofcourse I bent the rears back a few times before I actually changed them. I do race on a smaller (75x45) indoor track. I am sure if I raced it outdoors I would of broken the axles much sooner.
Most of the guys at my local track have gone to cvds. I was going to but figured why not just buy another truck.
Should have it this week. Tower shipped it monday. Wont get to race it until next week though.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
gixxer
gixxer's Avatar
02.28.2010, 12:47 AM
Well here is the final result. Should be trying it out at the track for the first time this week. So far I just put thicker oil in it 50wt and moved the shocks out on tower. Added a mmp, airtronics 94758 servo, novak 6.5hv and some new tires and wheels.
Shark413
Shark413's Avatar
02.28.2010, 04:31 AM
[QUOTE=gixxer;352471]Well here is the final result. Should be trying it out at the track for the first time this week. So far I just put thicker oil in it 50wt and moved the shocks out on tower. Added a mmp, airtronics 94758 servo, novak 6.5hv and some new tires and wheels.
Gixxer, looking good. What wheels/tires are those?
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
gixxer
gixxer's Avatar
02.28.2010, 09:40 AM
those are proline split six wheels with bowties. I like the yellow. http://www.prolineracing.com/product...ls-435-33.html
superek4
superek4's Avatar
03.10.2010, 02:15 AM
Where to buy snr shock towers?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
gixxer
gixxer's Avatar
03.10.2010, 07:02 AM
guy on the rctech forum. surprised you didn't see them there.
superek4
superek4's Avatar
03.10.2010, 09:47 AM
No just wonder what's the benefit as I am going to use 14mm shocks from x1 jammin cars.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Shark413
Shark413's Avatar
03.10.2010, 09:38 PM
The benefit is more travel. You want to increase the travel (in front) but you don't want to raise the ride height, so you need to increase the up-travel. The stock Jammin SCRT10 front shocks are really short and don't have enough travel. If you use the rear shocks in front (or any longer shock) you can gain some up travel. To use longer shocks you need the extended shock tower. Just don't get carried away with the front up travel as too much and your CVD's will bind under full compression. Use the SNR tower and stock Jammin rear shocks and you won't have any issues.
superek4
superek4's Avatar
03.10.2010, 10:19 PM
Can I use CRT .5 shock tower or can u point a link where I can get the snr towers? Thx
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Shark413
Shark413's Avatar
03.11.2010, 05:30 AM
Check this thread, Post #2022 the guy your looking for is "SNRSCION" send him a pm for more info. He has front and rear extended towers in Carbon fiber, 3mm or 4mm thickness.
http://www.rctech.net/forum/electric...ml#post7028198
superek4
superek4's Avatar
03.11.2010, 07:25 AM
Got it, pm him already thx
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
superek4
superek4's Avatar
03.13.2010, 05:43 AM
Can a neu 1512/2.5d motor fit in my scrt10?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Shark413
Shark413's Avatar
04.26.2010, 01:50 PM
Been a while since I posted any updates. I have been running the truck almost every weekend since I got it and it has held up well. I put a chassis shield on and it did a good job.
Chassis shield
Removing the shield
Chassis after a day at the track (outdoor, abrasive surface) about 5 packs. Only a few nicks on the leading edge, because I was in a hurry when I applied the shield and didn't overlap it on the edges.
Stock Jammin SCRT next to one with Slash size tires and an SC10 body.
Left: Stock Jammin wheels, Jammin rear shocks all the way around. Right: Slash wheels, 1/8 scale shocks.
Running 1/8 scale shocks front and back.
JoFreak
JoFreak's Avatar
04.26.2010, 03:50 PM
Nice SCRT10, I think I read your thread in the RSC forums half a dozen times.
I definately will use that idea with the skateboard glide tape for my truck.
Reminds me that I still have to order it...
Shark413
Shark413's Avatar
04.26.2010, 09:02 PM
JoFreak, thanks for the kind words. It's a little extra effort to take pictures and post up the info, but I learned a lot on these threads so I want to return the favor. How's your SCRT10 running?
