I made the conversion to accept the mechanical brakes(and ran it this way with the HV180 boat ESC), but i prefer motor braking personally - the mechanical brakes fade, run hot and add complexity to the simple E-theme. Reverse is nice, too.
I am also testing the ESC, so I want to test it in real world conditions - I will be gearing it up and driving like an idiot to simulate the gamut of driving conditions these may see. So far, the ESC has held up like a champ and even without the fan plugged in, the ESC hasn't gotten over 130 degrees or so. I suspect taller gearing may heat things up a bit, but I am thinking the ESC won't likely be the weak link in a normal setup.
