Help me find a power supply
naynay12
Help me find a power supply - 04.09.2010, 07:08 AM
For my hobbyking gt a-6 power supply i need a 240V power supply that can charge at 10a(so over 200w i presume,charging a 5000mah 5s 25c lipo.)
I could only find one that was $70 alone.Any links to cheaper ones?
V0RT3X
Muggy love
V0RT3X's Avatar
04.09.2010, 07:20 AM
I see that the max. voltage for that charger is 18V.
I bought one from here for my NET3(250W) charger but I got the 24V version:
http://cgi.ebay.com/15V-DC-23-2A-350...item2559851f4a
You will need to add the connectors for the input power plug (240V) and the output plugs for the charger.
http://www.rcgroups.com/forums/showthread.php?t=1154748
The power supply doesn't get hot when I charge 2S at 20A.
naynay12
04.09.2010, 07:21 AM
sorry double post
pinkpanda3310
pinkpanda3310's Avatar
04.09.2010, 07:28 AM
That gt a-6 charger looks to be only 50w max charge rate.
simplechamp
simplechamp's Avatar
04.09.2010, 09:36 AM
He probably has this one: http://www.hobbycity.com/hobbycity/s...idProduct=7386
pinkpanda3310
04.09.2010, 09:40 AM
OOPS! Sorry
04.09.2010, 10:04 AM
go on rcgroups forum and hit up feathermerchant. He sells some really good server power supplies that work like a charm. I have 2 of the big 46amp models, I can run 4 hyperions at the same time off 1 PS.
Heres a link to his site, easier if you are not a member or rcgroups: http://www.feathermerchantrc.com/
pinkpanda3310
04.09.2010, 11:12 AM
That link is for 120v PSU's, he needs 240v.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.09.2010, 12:25 PM
THANKS JAMES !
I was priceing PS's myself and was fustrated with some of the prices.
I bought a 42amp Model myself. Much Appreciated for posting
04.09.2010, 06:59 PM
I was looking for him as well...also thanks James!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.10.2010, 07:38 AM
Received shipping confirmation last night for my PS, This guy doesn't mess around !
FYI, He ships Priority mail.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.20.2010, 08:08 PM
Well I've ben using my "FeatherPower" 42amp inverter with great success, I even tried charging with my Hyperion Duo charging 2 5s packs and my Venom charger charging a 4s as advertised no even a hicup. Works perfectly as described !
The only thing I had a problem with was finding a plug for the power output side ?
I scored a plug from the local PC repair shop for free but struck out every where I went for the other. I wound up just soldering some wires directly to the output prongs of the inverter with a EC5 plug and a Deans on the other and she works flawlessly.
Here 2 pics befor I wired up the second outputs
ID:	8797   Click image for larger version
04.20.2010, 08:51 PM
Glad that worked for you Jeff. I have had excellent service from the 46amp model I got from him a while back. Even found the identical unit on ebay for 20 bucks, so I have a backup. I have run 4 hyperion chargers off mine and have not had an issue.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.20.2010, 08:56 PM
Thanks to you James !
You may be a serious ball breaker but your always looking out for us all.
